* | consolesimpletask.c: Fix Two Unchecked Return Values (CID #1437625 and #1472765) | Ryan Long | 2021-02-12 | 1 | -2/+5 |
| | | | | | | | CID 1437625: Unchecked return value from call to rtems_task_create(). CID 1472765: Unchecked return value from call to rtems_task_start(). Closes #4237. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | console: Use IMFS_add_node() for simple task cons | Sebastian Huber | 2020-03-04 | 1 | -20/+50 |
| | | | | | | | Change license to BSD-2-Clause according to file history. Update #3053. Update #3894. | ||||
* | console: Add missing return status | Sebastian Huber | 2018-06-27 | 1 | -0/+2 |
| | | | | Update #3320. | ||||
* | Add a simple task console driver | Sebastian Huber | 2018-03-06 | 1 | -0/+218 |
Close #3320. |
