* | cpukit/libcsupport/src/[a-f]*: Change license to BSD-2 | Joel Sherrill | 2022-04-01 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | cpukit/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -6/+0 |
| | | | | Updates #4625. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | Implement clock() | Sebastian Huber | 2017-09-07 | 1 | -0/+33 |
Newlib uses _times_r() in clock(). The problem is that the _times_r() clock frequency is defined by sysconf(_SC_CLK_TCK). The clock frequency of clock() is the constant CLOCKS_PER_SEC. FreeBSD uses getrusage() for clock(). Since RTEMS has only one process, the implementation can be simplified. Update #3121. |
