* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | Implement clock() | Sebastian Huber | 2017-09-07 | 1 | -0/+33 |
Newlib uses _times_r() in clock(). The problem is that the _times_r() clock frequency is defined by sysconf(_SC_CLK_TCK). The clock frequency of clock() is the constant CLOCKS_PER_SEC. FreeBSD uses getrusage() for clock(). Since RTEMS has only one process, the implementation can be simplified. Update #3121. |
