path: root/cpukit/libcsupport/src/base_fs.c (follow)
* Added support for configuring base filesystem. First attempt atJoel Sherrill1999-11-021-17/+41
| | | | | | a full mount table at initialization. This is the wrong place to mount filesystems 2-n since no device drivers are initialized yet.
* Added initial cut at miniIMFS which leaves out memfile and directoryJoel Sherrill1999-10-261-0/+7
| | | | | readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level.
* After comments D. V. Henkel-Wallace <gumby@zembu.com>, the interface toJoel Sherrill1999-06-151-1/+1
| | | | mount() was changed to avoid the use of a string as the options.
* Modifications for RTEMS_UNIX.Jennifer Averett1998-12-031-0/+2
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+81
