2022-05-04 | cpukit/libcsupport: Adding file headers and licenses | Ryan Long | 1 | -1/+28 | |
These files had no file header, copyright, or license. Based on git history, added appropriate copyright and license. | |||||
2020-04-16 | Canonicalize config.h include | Sebastian Huber | 1 | -1/+1 | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||||
2012-12-15 | libcsupport: Doxygen Enhancement Task #8 | Alex Ivanov | 1 | -3/+5 | |
http://www.google-melange.com/gci/task/view/google/gci2012/7996208 | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2007-03-26 | 2007-03-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+33 | |
* libcsupport/src/assoc.c, libcsupport/src/libio.c, libcsupport/src/write.c: Split files to shrink minimum.exe. Hopefully this will not be deemed necessary to commit to the 4.7 branch. * libcsupport/src/assoclocalbyname.c, libcsupport/src/assoclocalbyremote.c, libcsupport/src/assoclocalbyremotebitfield.c, libcsupport/src/assocnamebylocal.c, libcsupport/src/assocnamebylocalbitfield.c, libcsupport/src/assocnamebyremote.c, libcsupport/src/assocnamebyremotebitfield.c, libcsupport/src/assocptrbylocal.c, libcsupport/src/assocptrbyname.c, libcsupport/src/assocptrbyremote.c, libcsupport/src/assocremotebylocal.c, libcsupport/src/assocremotebylocalbitfield.c, libcsupport/src/assocremotebyname.c, libcsupport/src/libio_init.c, libcsupport/src/write_r.c: New files. |
