path: root/cpukit/libcsupport/src/access.c (follow)
* 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-081-0/+4
| | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+46
