path: root/cpukit/libcsupport/src/_realloc_r.c (follow)
* basdefs.h: Add and use RTEMS_UNUSEDSebastian Huber2015-10-261-1/+2
* libcsupport: Doxygen Enhancement Task #3Mathew Kallada2012-12-081-2/+7
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7992210
* Rework autoconf defines.Ralf Corsepius2009-09-301-1/+1
* Add __attribute__((unused)) to function arguments.Ralf Corsepius2009-09-151-1/+1
* 2007-12-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-12-181-0/+30
* libcsupport/Makefile.am, libcsupport/preinstall.am, libcsupport/src/malloc.c, libcsupport/src/mallocinfo.c, libmisc/Makefile.am, libmisc/shell/main_mallocinfo.c, libmisc/shell/shellconfig.h: Split malloc.c into multiple files with one function per file. Also split out statistics into a separate file which can be plugged in dynamically. Right now, it is always in. I suspect that splitting the file removed more code than leaving statistics in. I tinkered with malloc information command in the shell. I resurrected the malloc arena code as malloc boundary. This code is now compiled all the time even though it does not appear to work. * libcsupport/include/rtems/malloc.h, libcsupport/src/_calloc_r.c, libcsupport/src/_free_r.c, libcsupport/src/_malloc_r.c, libcsupport/src/_realloc_r.c, libcsupport/src/calloc.c, libcsupport/src/free.c, libcsupport/src/malloc_boundary.c, libcsupport/src/malloc_get_statistics.c, libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_p.h, libcsupport/src/malloc_report_statistics.c, libcsupport/src/malloc_report_statistics_plugin.c, libcsupport/src/malloc_statistics_helpers.c, libcsupport/src/malloc_walk.c, libcsupport/src/realloc.c, libmisc/shell/main_perioduse.c: New files.
