Fix _times().
TOD_MILLISECONDS_TO_TICKS().
http://www.google-melange.com/gci/task/view/google/gci2012/7996208
* libcsupport/src/__times.c: Formatting.
* libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c,
libcsupport/src/__times.c, libcsupport/src/libio_init.c,
libcsupport/src/mallocfreespace.c, libcsupport/src/mount-mgr.c,
libcsupport/src/mount.c, libcsupport/src/rewinddir.c,
libcsupport/src/seekdir.c, libcsupport/src/telldir.c,
libcsupport/src/unmount.c, libfs/src/dosfs/fat.c,
libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_rename.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/shell/vis.c, libmisc/stackchk/check.c, sapi/src/posixapi.c,
telnetd/telnetd.c: Remove include of assert.h when it is not needed.
* libcsupport/src/__brk.c, libcsupport/src/__gettod.c,
libcsupport/src/__times.c, libcsupport/src/fchdir.c,
libcsupport/src/ftrylockfile.c, libcsupport/src/getpwent.c,
libcsupport/src/gxx_wrappers.c, libcsupport/src/libio_sockets.c,
libcsupport/src/pipe.c: Use rtems_set_errno_and_return_minus_one()
where it was missed before.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagedata.c,
libmisc/cpuuse/cpuusagereport.c, libmisc/cpuuse/cpuusagereset.c,
rtems/include/rtems/rtems/types.h, rtems/src/ratemongetstatistics.c,
rtems/src/ratemonreportstatistics.c, score/src/threaddispatch.c,
score/src/threadinitialize.c, score/src/threadtickletimeslice.c:
Updated copyright line.
* configure.ac, libcsupport/src/__times.c,
libmisc/cpuuse/cpuusagedata.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, rtems/include/rtems/rtems/ratemon.h,
rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c,
score/include/rtems/score/thread.h, score/src/threaddispatch.c,
Changed the configuration of statistics granularity to use just one
define.
* libcsupport/src/__times.c, libfs/src/nfsclient/src/nfsTest.c,
libfs/src/nfsclient/src/rpcio.c: Convert calls to legacy routine
rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx().
* libcsupport/src/__times.c, posix/src/adjtime.c,
posix/src/clockgetres.c, posix/src/sysconf.c,
rtems/src/clockgettickspersecond.c, rtems/src/clockgettod.c,
rtems/src/clockset.c, rtems/src/clocktodvalidate.c,
score/src/timespecfromticks.c, score/src/timespectoticks.c,
score/src/ts64toticks.c: More case converted to use configuration
table entry not _TOD_Microseconds_per_tick.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, posix/src/clockgettime.c,
posix/src/pthread.c, posix/src/timersettime.c,
rtems/src/clockgetsecondssinceepoch.c, rtems/src/clockgetuptime.c,
rtems/src/ratemonreportstatistics.c, rtems/src/taskwakewhen.c,
rtems/src/timerfirewhen.c, rtems/src/timerserver.c,
rtems/src/timerserverfirewhen.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/thread.h,
score/include/rtems/score/tod.h, score/src/coretod.c,
score/src/coretodget.c, score/src/coretodgetuptime.c,
score/src/coretodset.c, score/src/coretodtickle.c,
score/src/threaddispatch.c, score/src/threadinitialize.c: Add
SuperCore handler Timestamp to provide an opaque class for the
representation and manipulation of uptime, time of day, and the
difference between two timestamps. By using SuperCore Timestamp, it
is clear which methods and APIs really have to be struct timespec and
which can be in an optimized native format.
* score/include/rtems/score/timestamp.h,
score/src/coretodgetuptimetimespec.c: New files.
libmisc/cpuuse/cpuusagereset.c, libmisc/monitor/mon-task.c,
rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemongetstatus.c,
rtems/src/ratemonperiod.c, score/include/rtems/score/thread.h,
score/src/threaddispatch.c, score/src/threadinitialize.c,
score/src/threadtickletimeslice.c: Add typedefs for cpu usage and
period timing statistics. Also renamed related variables and
structure members so they are the same whether you are using
nanosecond (e.g. struct timespec) or ticks (e.g. uint32_t)
granularity. This lays the groundwork for future cleanup.
* ChangeLog, configure.ac, libcsupport/src/__times.c,
libmisc/cpuuse/cpuuse.c, libmisc/stackchk/check.c,
rtems/src/ratemonperiod.c, rtems/src/ratemonreportstatistics.c,
rtems/src/ratemonresetall.c, rtems/src/ratemontimeout.c,
score/Makefile.am, score/include/rtems/score/thread.h,
score/include/rtems/score/timespec.h, score/src/threaddispatch.c,
score/src/threadinitialize.c, score/src/threadtickletimeslice.c,
score/src/timespecdivide.c: Add nanoseconds granularity to the rate
monotonic period statistics and CPU usage statistics. This capability
is enabled by default although may be conditionally disabled by the
user. It could be too much overhead on small targets but it does not
appear to be bad in early testing. Its impact on code size has not
been evaluated either. It is possible that both forms of statistics
gathering could be disabled with further tweaking of the conditional
compilation.
* score/src/timespecdividebyinteger.c: New file.
* include/chain.h, include/clockdrv.h, include/console.h,
include/iosupp.h, include/rtc.h, include/spurious.h,
include/timerdrv.h, include/vmeintr.h, include/motorola/mc68230.h,
include/rtems/libio_.h, include/rtems/termiostypes.h,
include/sys/termios.h, include/zilog/z8036.h, include/zilog/z8530.h,
include/zilog/z8536.h, src/__brk.c, src/__gettod.c, src/__sbrk.c,
src/__times.c, src/access.c, src/base_fs.c, src/cfgetispeed.c,
src/cfgetospeed.c, src/cfsetispeed.c, src/cfsetospeed.c, src/chdir.c,
src/chmod.c, src/chown.c, src/chroot.c, src/close.c, src/ctermid.c,
src/dup.c, src/dup2.c, src/eval.c, src/fchdir.c, src/fchmod.c,
src/fcntl.c, src/fdatasync.c, src/fpathconf.c,
src/fs_null_handlers.c, src/fstat.c, src/fsync.c, src/ftruncate.c,
src/getdents.c, src/getpwent.c, src/hosterr.c, src/ioctl.c,
src/isatty.c, src/libio.c, src/libio_sockets.c, src/link.c,
src/lseek.c, src/lstat.c, src/malloc.c, src/mallocfreespace.c,
src/mkdir.c, src/mkfifo.c, src/mknod.c, src/mount.c, src/newlibc.c,
src/no_libc.c, src/no_posix.c, src/open.c, src/pathconf.c,
src/pipe.c, src/privateenv.c, src/read.c, src/readlink.c,
src/rewinddir.c, src/rmdir.c, src/seekdir.c, src/stat.c,
src/symlink.c, src/sync.c, src/tcdrain.c, src/tcflow.c,
src/tcflush.c, src/tcgetattr.c, src/tcgetprgrp.c, src/tcsendbreak.c,
src/tcsetattr.c, src/tcsetpgrp.c, src/telldir.c, src/termios.c,
src/termiosinitialize.c, src/truncate.c, src/umask.c, src/unixlibc.c,
src/unlink.c, src/unmount.c, src/utime.c, src/write.c: URL for
license changed.
* src/__times.c: Corrected from previous attempt to cleanup.
* src/__times.c: Cleaned up comments, return more information,
and eliminated the fatal error on clock not set since it cannot
occur.
PROBLEMS
can/will be fixed.
