#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
TOD_MILLISECONDS_TO_TICKS().
http://www.google-melange.com/gci/task/view/google/gci2012/7996208
* libcsupport/src/__brk.c, libcsupport/src/__gettod.c,
libcsupport/src/__times.c, libcsupport/src/fchdir.c,
libcsupport/src/ftrylockfile.c, libcsupport/src/getpwent.c,
libcsupport/src/gxx_wrappers.c, libcsupport/src/libio_sockets.c,
libcsupport/src/pipe.c: Use rtems_set_errno_and_return_minus_one()
where it was missed before.
* libcsupport/src/__gettod.c: Rework autoconf defines.
Eliminate RTEMS_UNIX.
* itron/src/itrontime.c, libcsupport/src/__gettod.c,
posix/src/clockgettime.c, posix/src/clocksettime.c,
posix/src/nanosleep.c, posix/src/posixtimespecsubtract.c,
posix/src/posixtimespectointerval.c, posix/src/ptimer1.c,
posix/src/sleep.c, rtems/Makefile.am,
rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/timer.h,
rtems/include/rtems/rtems/types.h, rtems/src/clockget.c,
rtems/src/clockset.c, rtems/src/clocktodtoseconds.c,
rtems/src/clocktodvalidate.c, rtems/src/taskwakewhen.c,
score/Makefile.am, score/include/rtems/score/tod.h,
score/inline/rtems/score/tod.inl, score/src/coretod.c,
score/src/coretodset.c: Convert from Classic API style TOD_Control as
fundamental time structure to POSIX struct timespec. Add
clock_get_uptime().
* rtems/src/clockgetuptime.c, score/src/coretodget.c,
score/src/coretodgetuptime.c: New files.
* score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c: Removed.
* libcsupport/src/__gettod.c: Replace incorrect comment about timezone
support and remove deadcode. Replace with comment explaining that
behavior is compatible with GNU/Linux per Eric Norum.
* libcsupport/include/chain.h, libcsupport/include/clockdrv.h,
libcsupport/include/ringbuf.h, libcsupport/include/spurious.h,
libcsupport/include/timerdrv.h, libcsupport/include/vmeintr.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/libio.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h,
libcsupport/include/zilog/z8536.h, libcsupport/src/__gettod.c,
libcsupport/src/assoc.c, libcsupport/src/assocnamebad.c,
libcsupport/src/error.c, libcsupport/src/libio.c,
libcsupport/src/libio_sockets.c, libcsupport/src/malloc.c,
libcsupport/src/no_libc.c, libcsupport/src/termios.c,
libcsupport/src/termiosreserveresources.c: Convert to using c99
fixed-size types.
* include/chain.h, include/clockdrv.h, include/console.h,
include/iosupp.h, include/rtc.h, include/spurious.h,
include/timerdrv.h, include/vmeintr.h, include/motorola/mc68230.h,
include/rtems/libio_.h, include/rtems/termiostypes.h,
include/sys/termios.h, include/zilog/z8036.h, include/zilog/z8530.h,
include/zilog/z8536.h, src/__brk.c, src/__gettod.c, src/__sbrk.c,
src/__times.c, src/access.c, src/base_fs.c, src/cfgetispeed.c,
src/cfgetospeed.c, src/cfsetispeed.c, src/cfsetospeed.c, src/chdir.c,
src/chmod.c, src/chown.c, src/chroot.c, src/close.c, src/ctermid.c,
src/dup.c, src/dup2.c, src/eval.c, src/fchdir.c, src/fchmod.c,
src/fcntl.c, src/fdatasync.c, src/fpathconf.c,
src/fs_null_handlers.c, src/fstat.c, src/fsync.c, src/ftruncate.c,
src/getdents.c, src/getpwent.c, src/hosterr.c, src/ioctl.c,
src/isatty.c, src/libio.c, src/libio_sockets.c, src/link.c,
src/lseek.c, src/lstat.c, src/malloc.c, src/mallocfreespace.c,
src/mkdir.c, src/mkfifo.c, src/mknod.c, src/mount.c, src/newlibc.c,
src/no_libc.c, src/no_posix.c, src/open.c, src/pathconf.c,
src/pipe.c, src/privateenv.c, src/read.c, src/readlink.c,
src/rewinddir.c, src/rmdir.c, src/seekdir.c, src/stat.c,
src/symlink.c, src/sync.c, src/tcdrain.c, src/tcflow.c,
src/tcflush.c, src/tcgetattr.c, src/tcgetprgrp.c, src/tcsendbreak.c,
src/tcsetattr.c, src/tcsetpgrp.c, src/telldir.c, src/termios.c,
src/termiosinitialize.c, src/truncate.c, src/umask.c, src/unixlibc.c,
src/unlink.c, src/unmount.c, src/utime.c, src/write.c: URL for
license changed.
PROBLEMS
can/will be fixed.
of seconds since 1988 from RTEMS and not adding in the 1970-1988 correction
factor. Plus removed checks for data/time set since POSIX does not permit
this call to fail. GNAT 3.12 depends on this.
Bug report from Olivier Hainque <hainque@inf.enst.fr> on SPARC Solaris 2.6.
