* | __assert.c: Fix missing prototype warnings | Joel Sherrill | 2013-09-22 | 1 | -1/+2 |
* | score: Add and use rtems_assert_context | Sebastian Huber | 2013-02-12 | 1 | -1/+8 |
* | libcsupport: Doxygen enhancement GCI task #6 | Alex Ivanov | 2012-12-11 | 1 | -2/+13 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7992212 | ||||
* | score: Add RTEMS_FATAL_SOURCE_ASSERT | Sebastian Huber | 2012-11-15 | 1 | -1/+1 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-29 | 1 | -2/+2 |
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 1 | -2/+3 |
| | | | | * libcsupport/src/__assert.c: Rework autoconf defines. | ||||
* | Conditionally build __assert(). | Ralf Corsepius | 2009-03-11 | 1 | -0/+2 |
* | 2008-01-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-01-09 | 1 | -16/+13 |
| | | | | | * libcsupport/src/__assert.c: Clean up and make __assert() call __assert_func(). | ||||
* | 2008-01-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-01-09 | 1 | -4/+31 |
| | | | | | * libcsupport/src/__assert.c: Newlib 1.16.0 adds __assert_func(). We need to have it also. | ||||
* | 2007-03-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-30 | 1 | -0/+4 |
| | | | | * libcsupport/src/__assert.c: Add HAVE_CONFIG_H. | ||||
* | 2007-03-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-03-28 | 1 | -0/+21 |
PR 1234/cpukit * libcsupport/Makefile.am: Provide printk() based implementation of __assert() to reduce dependencies in executables. * libcsupport/src/__assert.c: New file. |
