configurations could see it while including <sys/ioctl.h> and
<sys/ioccom.h>.
of all FIO constants and conflict with libnetworking code.
significant things:
and PowerPC
same code base.
initialization.
readdir support. The next step is to add a mount table and configure
either the miniIMFS or the full IMFS at the application level.
Renamed IMFS handler tables to include IMFS prefix.
places to make sure memory allocated for filesystem specifif nodes
gets freed.
mount() was changed to avoid the use of a string as the options.
for simplicity.
There seems to be an ugly dependency between posix-headers and
libcsupport.
Configuring rtems with
../rtems-rc-19990324-0/configure \
--target=i386-rtems \
--prefix=<somewhere> \
--disable-posix
"make RTEMS_BSP=pc386" results into:
/opt/rtems/bin/i386-rtems-gcc --pipe
-B/users/rtems/src/multi/build/pc386/lib/ -specs bsp_specs -qrtems
-I/users/rtems/src/multi/build/pc386/lib/include/networking -g -Wall
-ansi -fasm -O4 -fomit-frame-pointer -c -o o-pc386/utime.o
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c
In file included from
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:16:
/opt/rtems/i386-rtems/include/utime.h:4: sys/utime.h: No such file or
directory
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:24: warning:
`struct utimbuf' declared inside parameter list
its scope is only this definition or declaration,
which is probably not what you want.
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c: In function
`utime':
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:34:
dereferencing pointer to incomplete type
make[4]: *** [o-pc386/utime.o] Error 1
make[3]: *** [all] Error 1
make[2]: *** [all] Error 1
make[1]: *** [all] Error 1
make[1]: Leaving directory `/lfs/poseidon/users/rtems/src/multi/build/c'
make: *** [all] Error 1
Apparently sys/utime.h is one of the posix headers and therefore gets
not installed (I suppose this is correct).
IMO, this probably indicates that sys/utime.h has to be moved to another
include subdirectory and should not be part of the posix-package.
[AFAIK, sys/*.h are system dependent headers, so why should it be a
posix-header? - Hmm]
fcntl support and an external fcntl handler for sockets.
would work. At the same time, the initial implementation of F_SETFL
was added. A support routine was added to convert internal libio
flags back to the POSIX style. Eventually the internal representation
should be eliminated in the interest of simplicity and code reduction.
This problem was reported by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>.
<ian@airs.com> to fix this problem:
There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It
does not check whether the file descriptor it is passed is open. This
can cause it to make a null dereference if it is passed a file
descriptor which is in the valid range but which was not opened, or
which was already closed.
all conflicts.
Date: Sat, 5 Dec 98 13:20:51 -0600
What do you think of this patch? It implements your `tap'
suggestion in a way that adds support for all ethernet devices with
no driver modifications. I also added a return value from the tap
function. If the return value is zero, the packet will be passed up
the chain as usual. If the return value is non-zero the mbuf holding
the packet will be freed and the packet will be dropped.
If you like it, please submit it to Joel.
I guess there needs to be an addition to the network documentation
describing the additional ioctl's -- and a big warning that the tap
function is called from a context that holds the network semaphore.
Here is Eric's patch. I've tested it a bit, and made a couple of
trivial changes. This is certainly better than mine: it should work
for all Ethernet drivers.
The only concern I have about this patch is that the tap function may
want to fiddle with the mbuf, calling functions like m_pullup and the
like. If those force the networking code to rearrange the mbuf
structure, then the caller's call to m_freem may crash. I don't know
if this is a realistic concern--I don't know enough about the mbuf
layer.
PROBLEMS
can/will be fixed.
with libchip.
1. Finally fixes raw interrupts for pc386
2. Makes some minor cleanup in console and startup
3. Makes rtems_termios_dequeue_characters() to return count of
outstanding chars - it allows to simplify console isrs a little
bit.
4. pc386 uart modified to be friendlier to termios parameter changes,
to have minor performance improvement and to take advantage of
of above termios modification.
Eric Norum per request from Geoffroy Montel:
> The rtems_termios_enqueue_raw_characters function type is void.
> The problem is that I can't return an error message if the input
> buffer is full.
> Could we add a return value?
Sure, but what would you do with the overflow indication? POSIX says,
``when the input limit is reached, the saved characters are thrown away
without notice''.
Anyhow, the change is so small I've done it and enclosed the patch.
support for device driver support on tcsetattr(), and hardware
flow control callbacks.
a result of enabling the newlib POSIX directory.
properly reflect the const on the buffer pointer being passed in.
Added new entry point to add in per physical port resource requirements.
(Sapporo, Japan) submitted the extended console driver for the
MVME162LX BSP and the POSIX tcsetattr() and tcgetattr() routines.
This device driver supports four serial ports, cooked IO, and
provides a portable base for Zilog 8530 based console drivers.
