path: root/cpukit/libcsupport/include (follow)
* SPARC port passes all testsJoel Sherrill1995-10-301-7/+18
* fixed missing CVS IDsJoel Sherrill1995-10-061-0/+1
* posix support initially addedJoel Sherrill1995-09-261-0/+48
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-4/+33
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-174-19/+183
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Added functions to access the errno of the native system when using theJoel Sherrill1995-08-111-7/+2
| | | | newlib C library.
* moved ringbuf.h to a shared include directoryJoel Sherrill1995-08-011-0/+42
* Initial revisionJoel Sherrill1995-05-117-0/+325
