line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This assert helps to detect an invalid reference counting in RTEMS_DEBUG
configurations.
Update #3132.
Update #3136.
Check iop reference count in close() and return -1 with errno set to
EBUSY in case the file descriptor is still in use.
Update #3132.
Update #3132.
Replace rtems_libio_check_fd(), rtems_libio_iop(),
rtems_libio_check_open() and rtems_libio_check_permissions()
combinations with new LIBIO_GET_IOP() and LIBIO_GET_IOP_WITH_ACCESS()
macros.
Update #3132.
Update #3132.
Update #3132.
Rename rtems_libio_check_permissions_with_error() in
rtems_libio_check_permissions().
Update #3132.
Remove rtems_libio_check_permissions() and convert single user to
rtems_libio_check_permissions_with_error().
Update #3132.
This simplifies error handling later.
Update #3132.
Remove the file descriptor validation. This is the job of
rtems_libio_check_fd(). Use an inline function instread of a macro.
Update #3132.
The top-level IO library structures should contain no special-case data.
Update #2859.
Update #2859.
Perform a context-dependent deferred location release to avoid a
deadlock on the file system instance locks, for example during a
chdir().
Update #2936.
Add path length parameter to
rtems_filesystem_eval_path_start_with_root_and_current() so that users
may pass paths without a '\0' termination.
Update #2558.
Drop parameter check from previously unused
rtems_libio_iop_to_descriptor().
Use the fstat handler instead.
Add a local context structure to the SMP lock API for acquire and
release pairs. This context can be used to store the ISR level and
profiling information. It may be later used to enable more
sophisticated lock algorithms, e.g. MCS locks.
There is only one lock that cannot be used with a local context. This
is the per-CPU lock since here we would have to transfer the local
context through a context switch which is very complicated.
Split the dub call into dup and dup2 in fcntl.c. This requires
a private command which is placed in the internal libio header.
Implement POSIX requirements in the high-level file system layer. Use
common implementation for all change owner variants.
This is the result of a sed script which converts all uses
of @{ into a consistent form.
http://www.google-melange.com/gci/task/view/google/gci2012/7996208
http://www.google-melange.com/gci/task/view/google/gci2012/8009205
http://www.google-melange.com/gci/task/view/google/gci2012/7975223
http://www.google-melange.com/gci/task/view/google/gci2012/7992211
http://www.google-melange.com/gci/task/view/google/gci2012/8017203
http://www.google-melange.com/gci/task/view/google/gci2012/7992210
Rename rtems_filesystem_location_exists_in_same_fs_instance_as() into
rtems_filesystem_location_exists_in_same_instance_as() for consistency
with other file system instance related functions.
