path: root/cpukit/libcsupport/include/rtems/error.h (follow)
* score: Change debug helper functionsSebastian Huber2014-02-121-2/+0
| | | | | | | | Rename rtems_internal_error_description() to rtems_internal_error_text(). Rename rtems_fatal_source_description() to rtems_fatal_source_text(). Rename rtems_status_code_description() to rtems_status_text(). Remove previous implementation of rtems_status_text().
* Expose rtems_verror()Nick Withers2013-08-151-3/+24
* cpukit: Doxygen group fixes and many warnings addressedJoel Sherrill2013-01-101-5/+9
| | | | | | | The output of the modules.html is much improved. Most filesystem and POSIX API related groups are properly nested. Some formatting issues were addressed as were multiple inconsistencies.
* Header File Doxygen Enhancement Task #7Mathew Kallada2012-12-281-7/+9
* libcsupport: Doxygen enhancement GCI task #4Alex Ivanov2012-12-111-0/+61
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/8009205
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-3/+0
* 2011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-241-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h, include/rtems/pci.h, include/rtems/userenv.h, libblock/include/rtems/flashdisk.h, libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/spurious.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/framebuffer.h, libcsupport/include/rtems/gxx_wrappers.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/malloc.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h, libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h, libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h, libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h, libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h, libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h, libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h, posix/include/mqueue.h, posix/include/semaphore.h, posix/include/rtems/posix/aio_misc.h, posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/sigset.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, rtems/mainpage.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/barrier.inl, rtems/inline/rtems/rtems/timer.inl, rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h, sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h, score/include/rtems/score/object.h, score/include/rtems/score/priority.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl: Add @file Doxygen directives and descriptions to files which originated with RTEMS. This improves the file list page generated by Doxygen.
* 2011-02-23 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-231-1/+2
| | | | | | * libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/spurious.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/libcsupport.h: Add missing includes.
* 2010-06-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-06-281-14/+11
| | | | | | * libcsupport/include/rtems/error.h, libcsupport/src/error.c: Clean up so rtems_panic() can be a noreturn method. This eliminates some unreachable and thus untestable code.
* 2009-10-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-221-0/+7
| | | | | | * libcsupport/include/rtems/error.h: Use ordinal constants for RTEMS_ERROR_ERRNO, RTEMS_ERROR_PANIC, RTEMS_ERROR_ABORT to avoid implicit constant conversion overflows on 16bit-int targets.
* Introduce rtems_error_code_t.Ralf Corsepius2009-10-121-2/+6
| | | | Minor portability code-massaging.
* New header guards.Ralf Corsepius2005-01-281-2/+2
* Add doxygen preamble.Ralf Corsepius2004-12-021-0/+4
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-0/+9
* removed noreturn attribute to eliminate warnings.Joel Sherrill1997-04-071-2/+7
* updates from Tony BennettJoel Sherrill1996-04-221-4/+5
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-151-4/+10
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-0/+26
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
