brains GmbH.
context after they are finialized after r336539, so do not do it.
Submitted by: David CARLIER <devnexen gmail com>
MFC after: 1 month (after r336539)
Differential Revision: https://reviews.freebsd.org/D16059
copied_key and copied_salt are assigned with NULL and never used
otherwise. Remove the two variables and related code.
Reviewed by: pfg
MFC after: 2 weeks
Differential Revision: https://reviews.freebsd.org/D16314
Mainly focus on files that use BSD 2-Clause license, however the tool I
was using mis-identified many licenses so this was mostly a manual - error
prone - task.
The Software Package Data Exchange (SPDX) group provides a specification
to make it easier for automated tools to detect and summarize well known
opensource licenses. We are gradually adopting the specification, noting
that the tags are considered only advisory and do not, in any way,
superceed or replace the license texts.
Mainly focus on files that use BSD 3-Clause license.
Special thanks to Wind River for providing access to "The Duke of
Highlander" tool: an older (2014) run over FreeBSD tree was useful as a
starting point.
Updates #4625.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Add crypt_add_format(), crypt_r(), crypt_md5_r(), crypt_sha256_r() and
crypt_sha512_r().
