All resource allocations take place in rtems_bdbuf_init() now. After
rtems_bdbuf_init() no fatal errors can happen due to configuration
errors or resource limits. This makes it easier to detect
configuration errors for users.
This is the result of a sed script which converts all uses
of @{ into a consistent form.
Use rtems_blkdev_create_partition() instead of rtems_disk_create_log()
to avoid problems with the huge IMFS_GENERIC_DEVICE_MAJOR_NUMBER.
Add rtems_bdbuf_fatal_code as a replacement for the previous fatal error
codes. Remove unused error codes. Add new error codes. Use
rtems_fatal() with RTEMS_FATAL_SOURCE_BDBUF as source.
Add and use rtems_blkdev_request_done(). Block device transfer requests
must signal the completion status now with rtems_blkdev_request_done().
The return value of the block device IO control will be ignored for
transfer requests.
The first parameter of rtems_blkdev_request_cb is now the transfer
request structure.
Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to
break third party drivers at compile time, otherwise this API change
would result in runtime errors.
The set block size must synchronize and purge the disk to avoid an
inconsistent cache state and data corruption. The synchronization is
optional depending on the new sync parameter. In some contexts a
synchronization must not be performed, e.g. during disk creation.
In case the read-ahead task is not configured we must not send a wake-up
event. This would send the wake-up event to the executing task.
We must send the wake-up event only in case the request list changes
from empty to non-empty. Since otherwise we may send a false transfer
event.
In case the read-ahead task has a higher priority than the reading task,
this ensures that the read-ahead request is issued after the read miss
is serviced.
The previous version was sub-optimal for read-ahead transfer counts of
one.
This allows addtion of per disk statistics for example.
Read-ahead requests were previously executed in the context of the
reading task. This blocks the reading task until the complete read
with read-ahead transfer is finished. A read-ahead task is introduced
to off-load the read-ahead transfer. This allows the reading task to
work with the requested block more quickly. The read-ahead is triggered
after two misses of ascending consecutive blocks or a read hit of a
block read by the most-recent read-ahead transfer. The read-ahead
feature is configurable and can be disabled.
Move rtems_bdbuf_get_media_block() call inside the bdbuf lock.
Add block_count and media_blocks_per_block to rtems_disk_device. Add
and use rtems_disk_init_phys() and rtems_disk_init_log().
The task stack size for the swap-out and worker tasks is now
configurable. The bdbuf task resources are now included in the work
space size estimate.
It is now the responsibility of the read() and write() handler to update
the offset field of the IO descriptor (rtems_libio_t). This change
makes it possible to protect the IO descriptor from concurrent access by
per file locks.
According to POSIX the lseek() function shall not, by itself, extend the
size of a file.
Remove the size field of rtems_libio_t. A file has only one size but
may have multiple open file descriptors. Thus a file size field in the
file descriptor may lead to inconsistencies.
New default handlers rtems_filesystem_default_lseek_file() and
rtems_filesystem_default_lseek_directory().
for details.
Check the availablity of a recycle destination segment only when it is
necessary to avoid missing resycle source segment erasures.
Do not use the unavailable block count as the erased blocks starvation
threshold. Use instead the block count of the largest segment. This
improves the starvation resolution gain of available blocks.
The new function rtems_bdbuf_set_block_size() must be used to set the
block size of a disk device. It will check if the block size is valid
and set the new fields block_to_media_block_shift and bds_per_group of
the rtems_disk_device structure. This helps to avoid complex arithmetic
operations in the block device buffer get and read path.
Calling the bdbuf API functions in the not configured state is now a
fatal error.
The transfer chain is accessed by at most one thread at a time.
The chains are protected by the bdbuf cache lock.
