* libblock/src/flashdisk.c:
Make rtems_fdisk_crc16_gen_factors static.
* libblock/src/nvdisk.c:
Make rtems_nvdisk_crc16_gen_factors static.
PR 1948/filesystem
* libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-rtems.c:
Add support for mount passing an ASCIIZ string containing
configuration options. Remove the hardcoded dir string and
size. Fix comments.
* libblock/src/bdbuf.c: Fix state labels in trace output.
* libblock/src/nvdisk-sram.c, libi2c/libi2c.c,
libmisc/shell/main_msdosfmt.c: Eliminate use of GNU old-style field
designator extension as recommended by clang.
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
* libblock/include/rtems/bdbuf.h: Documentation.
PR 1790/cpukit
* libblock/src/flashdisk.c: Fixed memset() parameters.
* libblock/src/media-path.c: Remove warnings.
* libblock/include/rtems/bdpart.h (rtems_bdpart_format):
Preserve previous API.
* libblock/src/bdpart-create.c, libblock/src/bdpart-read.c,
libblock/src/bdpart-write.c: Reflect changes above.
* libmisc/shell/fdisk.c: Reflect changes above.
Eliminate unnamed union (Non c99-compliant).
* libblock/src/blkdev-ops.c: New file.
* libblock/Makefile.am: Reflect change from above.
* libblock/include/rtems/blkdev.h: Declare rtems_blkdev_generic_ops.
* libblock/src/show_bdbuf.c, score/src/objectmp.c: Avoid chain API
violations.
* libblock/include/rtems/media.h, libblock/src/media-server.c: Use
chains instead of a message queue.
CID 114/SECURE_CODING
* libblock/src/media.c: Avoid strcpy().
CID 113/SECURE_CODING
* libblock/src/media-path.c: Avoid strcpy(). Style. Use assert() to
avoid dead code.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libcsupport/src/ioctl.c, libfs/src/dosfs/fat_file.c: Add va_end().
* libblock/src/media.c: Use unprotected chain extract.
* libblock/include/rtems/media.h, libblock/src/media-desc.c,
libblock/src/media-dev-ident.c, libblock/src/media-path.c,
libblock/src/media-server.c, libblock/src/media.c: New files.
* Makefile.am, preinstall.am, libblock/Makefile.am: Reflect changes
above.
* libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c,
libcsupport/src/__times.c, libcsupport/src/libio_init.c,
libcsupport/src/mallocfreespace.c, libcsupport/src/mount-mgr.c,
libcsupport/src/mount.c, libcsupport/src/rewinddir.c,
libcsupport/src/seekdir.c, libcsupport/src/telldir.c,
libcsupport/src/unmount.c, libfs/src/dosfs/fat.c,
libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_rename.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/shell/vis.c, libmisc/stackchk/check.c, sapi/src/posixapi.c,
telnetd/telnetd.c: Remove include of assert.h when it is not needed.
PR 1553/filesystem
Coverity Id 37
* libblock/src/flashdisk.c: Fix two paths which should have returned an
error but did not have the return statement.
PR 1524/filesystem
* libcsupport/src/rtems_mkdir.c: New file.
* libcsupport/src/Makefile.am: Reflect change above.
* libcsupport/include/rtems/libio.h: Added rtems_mkdir().
* libmisc/fsmount/fsmount.h, libmisc/fsmount/fsmount.c,
libblock/src/bdpart-mount.c, libnetworking/rtems/mkrootfs.h,
libnetworking/rtems/mkrootfs.c, libfs/src/pipe/pipe.c: Use
rtems_mkdir(). Removed rtems_fsmount_create_mount_point() and
rtems_rootfs_mkdir().
* libcsupport/Makefile.am: Add mount-mgr.c.
* libcsupport/src/mount-mgr.c: New.
* include/rtems/fs.h: Added rtems_filesystem_location_mount.
* libcsupport/include/rtems/libio.h, libcsupport/src/mount.c: New
mount interface. It is similar to Linux.
* libcsupport/include/rtems/libio_.h: Remove the
init_fs_mount_table call.
* libcsupport/src/base_fs.c: Remove init_fs_mount_table_call. Use
the new mount call. Remove setting the root node in the global
pathloc. Mount does this now.
* libcsupport/src/privateenv.c: Remove the hack to set the root
mount table entry in the environment.
* libcsupport/src/unmount.cL Free the target string.
* libblock/src/bdpart-mount.c: New mount API.
* libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_init.c,
libfs/src/dosfs/dosfs.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_init.c,
libfs/src/imfs/miniimfs_init.c,
libfs/src/nfsclient/src/librtemsNfs.h,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs.h,
libnetworking/lib/ftpfs.c, libnetworking/rtems/ftpfs.h,
libnetworking/rtems/tftp.h: New mount_h API.
* libfs/src/devfs/devfs_eval.c: Local include of extern ops.
* libfs/src/nfsclient/src/nfs.c: New mount API. Removed the mount
me call and fixed the initialisation to happen when mounting.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Remove mount
filesystem files.
* libmisc/fsmount/fsmount.c, libmisc/fsmount/fsmount.h: Updated to
the new mount table values.
* libmisc/shell/main_mount_ftp.c,
libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_rfs.c,
libmisc/shell/main_mount_tftp.c: Removed.
* libmisc/shell/main_mount.c: Use the new mount API. Also access
the file system table for the file system types.
* libnetworking/lib/tftpDriver.c: Updated to the new mount
API. Fixed to allow mounting from any mount point. Also can now
have more than file system mounted.
* sapi/include/confdefs.h: Add file system configuration support.
* libblock/include/rtems/nvdisk.h, libblock/src/nvdisk-sram.c:
Use pointer arithmetic instead of int32_t arithmetic for 16bit
compatibility.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c:
Cast argp to uintptr_t temporary instead of uint32_t temporary
(Avoid incompatible pointer casts on 16bit targets).
* libblock/src/diskdevs.c, libblock/include/rtems/blkdev.h,
libblock/src/bdbuf.c: PR 1448/filesystem.
* libblock/include/rtems/blkdev.h, libblock/src/bdbuf.c: PR
1514/filesystem.
PR 1449/cpukit
* libblock/src/diskdevs.c: rtems_disk_next() will now implicitly
obtain the returned disk.
* libblock/include/rtems/diskdevs.h: Documentation.
* libblock/src/flashdisk.c: Clean up on initialisation errors.
* libblock/src/bdpart.c: Removed file.
* libblock/src/bdpart-create.c, libblock/src/bdpart-dump.c,
libblock/src/bdpart-mount.c, libblock/src/bdpart-read.c,
libblock/src/bdpart-register.c, libblock/src/bdpart-sort.c,
libblock/src/bdpart-write.c: New files.
* libblock/include/rtems/bdpart.h: Moved some definitions from bdpart.c.
* libblock/Makefile.am: Update for file changes.
PR1507
* libblock/src/bdbuf.c: Avoid NULL pointer access.
* libblock/src/diskdevs.c: Fixed bounds check in rtems_disk_next().
Obtain/release disk during open/close
* libblock/src/ide_part_table.c: Functionality of
rtems_ide_part_table_get() and rtems_ide_part_table_free() was needed
internally but those routines are deprecated from the public API. So
move their contents to private static routines. Using the private
routines in this file avoids deprecation warnings and leaves
functional, although deprecated, versions for potential use by
applications.
* ftpd/ftpd.c, httpd/uemf.c, httpd/um.c, httpd/webs.c,
httpd/websuemf.c, libblock/src/diskdevs.c,
libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c,
libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c,
libmisc/uuid/parse.c, libnetworking/lib/ftpfs.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_network.c,
libnetworking/rtems/rtems_mii_ioctl.c,
score/src/objectgetnameasstring.c: Fix warnings for ctype methods.
* libblock/src/ramdisk-config.c: Revert accidental commit.
* libblock/src/ramdisk-config.c, sapi/include/confdefs.h:
CONFIGURE_DISABLE_CLASSIC_NOTEPADS is typo of
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS. Fix it.
* libblock/src/diskdevs.c: Create the devices as block devices.
* libmisc/shell/main_debugrfs.c, libmisc/shell/main_mkrfs.c,
libmisc/shell/main_mount_rfs.c: New.
* libmisc/shell/main_msdosfmt.c: Change the command to mkdos and
alias the old name.
* libmisc/shell/shellconfig.h, libmisc/Makefile.am: Add RFS
support.
* libfs/src/rfs/rtems-rfs-shell.c,
libfs/src/rfs/rtems-rfs-shell.h: Move the format command code into
the shell file.
* libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-bitmaps.h,
libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h,
libfs/src/rfs/rtems-rfs-block-pos.h,
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-buffer-devio.c,
libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h,
libfs/src/rfs/rtems-rfs-dir-hash.c,
libfs/src/rfs/rtems-rfs-dir-hash.h,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h,
libfs/src/rfs/rtems-rfs-file-system-fwd.h,
libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h,
libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h,
libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h,
libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c,
libfs/src/rfs/rtems-rfs-rtems.h,
libfs/src/rfs/rtems-rfs-rtems-utils.c,
libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h,
libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h:
New.
* Makefile.am, preinstall.am, libfs/Makefile.am,
wrapup/Makefile.am: Updated with the RFS support.
* libfs/README: Updated after 10 years.
libblock/src/ramdisk-driver.c: Updated to the new error reporting
in libblock.
* libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing
the size in long mode.
* libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bootp.c,
libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP
to the forever behaviour of 4.9 with the ability to call BOOTP and
control the process if required.
Coverity Id 7
Coverity Id 8
* libblock/src/bdpart.c: Verify libblock is really set after
rtems_bdbuf_read() before using it.
Coverity Id 10
* libblock/src/bdbuf.c: Rework loop conditional to avoid potential use
of NULL pointer.
* libblock/src/ide_part_table.c: Another error path without a
free(sector).
Coverity Id 24
* libblock/src/ide_part_table.c: Initialize sector to NULL and add
free(sector) on error return path from get_sector() to fix potential
leak.
Coverity Id 25
* libblock/src/ide_part_table.c: Add free(sector) on error return path
to fix leak.
Coverity Id 27
* libblock/src/ramdisk-config.c: Coverity notes that the
calloc() is a resource leak. This is allocating memory for
a RAM disk which will persist for the life of the system. RTEMS
has no "de-initialize" driver call so there is no corresponding
free(r). Coverity is correct that it is never freed but this is
not a problem.
Avoid designated initializers for C++ compatibility
Fixed invalid state transition from FRESH to CACHED
Free memory in case of an error.
