* Makefile.am: Eliminate LIBNAME. Cosmetical cleanups.
* configure.ac: RTEMS_TOP(../..).
* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* src/bdbuf.c: Modified as part of above.
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
* src/Makefile.am: Don't preinstall libblock.a.
Use ../aclocal.
Move from c/src/libblock to c/src/exec/libblock
* configure.ac: Reflect move.
* Makefile.am: Ditto.
* include/Makefile.am: Ditto.
* src/Makefile.am: Ditto.
* src/ramdisk.c: include <string.h>.
* src/blkdev.c: include <string.h>.
* include/rtems/bdbuf.h: Address PR168 by changing bdbuf_buffer.avl.bal
and bdbuf_buffer.avl.cache to signed char instead of char.
* ChangeLog: Undo incorrect addition of entry.
* net/if_ppp.c, net/ppp_tty.c: Initial preparations for multiple
PPPD connections.
* src/bdbuf.c (avl_insert, avl_remove): Reimplemented from scratch
to avoid using GPLed sources in RTEMS core.
* src/bdbuf.c, include/rtems/bdbuf.h: Remove "binary tree"
implementation which was used for debugging only.
* Submitted by Victor V. Vengerov <vvv@oktet.ru> and merged
into the RTEMS source.
* ChangeLog, Makefile.am, README, configure.ac, include/Makefile.am,
include/rtems/bdbuf.h, include/rtems/blkdev.h, include/rtems/diskdevs.h,
include/rtems/ramdisk.h, include/rtems/.cvsignore, include/.cvsignore,
src/Makefile.am, src/bdbuf.c, src/blkdev.c, src/diskdevs.c,
src/ramdisk.c, src/.cvsignore, .cvsignore: New files.
