path: root/cpukit/libblock (follow)
* 2008-05-01 Chris Johns <chrisj@rtems.org>Chris Johns2008-05-015-2/+1186
| | | | | | | | | * libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libblock/src/nvdisk-sram.c, libblock/src/nvdisk.c: New. A Non-volatile memory disk drive. * Makefile.am, preinstall.am, libblock/Makefile.am: Updated for the NV disk driver.
* 2008-01-23 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-01-231-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * itron/include/rtems/itron/object.h, itron/src/cre_tsk.c, libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c, libmisc/capture/capture.c, libmisc/monitor/mon-manager.c, libmisc/stackchk/check.c, posix/src/condinit.c, posix/src/keycreate.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c, posix/src/mqueueopen.c, posix/src/mqueueunlink.c, posix/src/mutexinit.c, posix/src/pbarrierinit.c, posix/src/prwlockinit.c, posix/src/pspininit.c, posix/src/pthreadcreate.c, posix/src/pthreadexit.c, posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c, posix/src/timercreate.c, rtems/src/barrierident.c, rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c, rtems/src/ratemonident.c, rtems/src/regionident.c, rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c, sapi/src/extensionident.c, score/Makefile.am, score/include/rtems/score/object.h, score/inline/rtems/score/object.inl, score/src/apimutexallocate.c, score/src/objectextendinformation.c, score/src/objectgetnameasstring.c, score/src/objectmp.c, score/src/objectnametoid.c: Convert the Objects_Name type from a simple type to a union of an unsigned 32 bit integer and a pointer. This should help eliminate weird casts between u32 and pointers in various places. The APIs now have to explicitly call _u32 or _string versions of helper routines. This should also simplify things and eliminate the need for ugly casts in some cases. * score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c: Removed.
* 2008-01-05 Chris Johns <chrisj@rtems.org>Chris Johns2008-01-052-251/+379
| | | | | | | | | | | | | | * configure.ac: Fix typo in the strict order mutex CPU OPTs test. * libmisc/shell/shell.c: Handle '#' comment characters correctly. * libblock/include/rtems/flashdisk.h: Add docmentation about the control fields. Add more control fields to handle the flash when full. * libblock/src/flashdisk.c: Fix the descriptor erase test so it detects a descriptor is erased. Add support for unavailable blocks the user can configure. Print the used list as a diag. Fix the bug when a page is detected as failed and present on more than one queue. Add a count to the queues so queue length can be used to manage compaction.
* 2007-12-22 Chris Johns <chrisj@rtems.org>Chris Johns2007-12-221-4/+6
| | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: fixed bug that always enabled strict order mutexes. * score/inline/rtems/score/coremutex.inl: Fixed coding standard. * score/src/coremutex.c: Add the holder's thread to the lock_mutex list if the mutex is initialised locked. * libnetworking/rtems/rtems_glue.c: Changed semaphore error message to show the error is an rtems-net error. * libmisc/monitor/mon-network.c: Removed warnings. * telnetd/icmds.c: Changed shell_* to rtems_shell_*. * score/Makefile.am: Fixed typo that stopped 'make tags' working. * libmisc/shell/err.c, libmisc/shell/err.h, libmisc/shell/errx.c, libmisc/shell/extern-cp.h, libmisc/shell/fts.c, libmisc/shell/fts.h, libmisc/shell/main_cp.c, libmisc/shell/utils-cp.c, libmisc/shell/verr.c, libmisc/shell/verrx.c, libmisc/shell/vwarn.c, libmisc/shell/vwarnx.c, libmisc/shell/warn.c, libmisc/shell/warnx.c: New. Ported from BSD. * libmisc/shell/shellconfig.h: Add the cp command. * libmisc/Makefile.am: Add the new files to the shell. * libmisc/shell/shell.c, libmisc/shell/shell.h: Add scripting support. * libblock/src/flashdisk.c: Fixed disk drive count size setting bug.
* 2007-12-12 Chris Johns <chrisj@rtems.org>Chris Johns2007-12-142-0/+8
| | | | | * libblock/include/rtems/flashdisk.h, libblock/src/flashdisk.c: Add RTEMS license details.
* 2007-12-12 Chris Johns <chrisj@rtems.org>Chris Johns2007-12-143-4/+2810
| | | | | | | | * Makefile.am, preinstall.am: Added libblock/include/rtems/flashdisk.h to the installed header list. * libblock/Makefile.am: Add flashdisk.c to the files to build. * libblock/include/rtems/flashdisk.h, libblock/src/flashdisk.c: New.
* 2007-05-08 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-05-081-0/+5
| | | | * libblock/src/show_bdbuf.c: Add HAVE_CONFIG_H magic.
* 2007-01-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-01-301-11/+11
| | | | * libblock/src/show_bdbuf.c: Use inttypes.h macros.
* 2007-01-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-01-271-904/+904
| | | | * libblock/src/show_bdbuf.c: Convert from DOS to UNIX.
* mproved gen5200 MSCAN driverThomas Doerfler2007-01-214-69/+982
| | | | fixed synchronization bug between ata.c and bdbuf.c
* 2006-11-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-11-211-1/+0
| | | | | * libblock/Makefile.am: Don't include preinstall.am. * libblock/preinstall.am: Remove.
* Remove (unused).Ralf Corsepius2006-11-211-7/+0
* applied patches for PR1117/1118/1119/1120Thomas Doerfler2006-07-092-5/+9
* 2006-03-07 Thomas Doerfler <Thomas.Doerfler@embedded-brains.de>Joel Sherrill2006-03-071-76/+342
| | | | | | | PR 852/filesystem * libblock/src/bdbuf.c: Increase performance of MSDOS file accesses by using a simple read-ahead and write-combining scheme. Improvement is dramatic.
* New.Ralf Corsepius2006-01-121-0/+7
* Remove all-local.Ralf Corsepius2006-01-121-2/+1
* 2005-07-05 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-07-051-1/+7
| | | | * libblock/include/rtems/ide_part_table.h: Add C++ guards.
* 2005-05-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-05-061-2/+2
| | | | | | | | * libblock/src/blkdev.c, libfs/src/dosfs/fat_file.c, libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_misc.c: Removed warnings.
* 2005-02-17 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-171-1/+1
| | | | | * libblock/include/rtems/diskdevs.h: Use uint32_t for ictrl req argument (16bit target compliance).
* 2005-02-17 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-172-3/+4
| | | | | | * libblock/include/rtems/ramdisk.h: size_t rtems_ramdisk_configuration_size. * libblock/src/ramdisk.c: Adaptations for 16bit target compliance.
* 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-081-43/+2
| | | | | | | * configure.ac: Add new header guard to cpuopts.h. * Makefile.am: Add libfs, libblock, ftpd header install rules. * libfs/Makefile.am, libblock/Makefile.am, ftpd/Makefile.am: Remove header install rules.
* 2005-02-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-02-023-10/+11
| | | | | | | | * libblock/include/rtems/bdbuf.h, libblock/include/rtems/ide_part_table.h, libblock/src/blkdev.c, libcsupport/include/rtems/termiostypes.h, libcsupport/src/termios.c, posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/mutex.inl : Remove warnings.
* New header guard.Ralf Corsepius2005-01-285-10/+10
* 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-281-2/+0
| | | | | | | * itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am, posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am: Remove AM_CPPFLAGS += -I$(top_builddir).
* 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-071-1/+1
| | | | | | | | * httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Fix typo.Ralf Corsepius2005-01-051-1/+1
* 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-011-9/+2
| | | | | | | | | * automake/compile.am, httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am, wrapup/Makefile.am: Remove build-variant support.
* 2004-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2004-11-225-13/+28
| | | | | | | | | * libblock/include/rtems/bdbuf.h, libblock/include/rtems/blkdev.h, libblock/include/rtems/diskdevs.h, libblock/include/rtems/ide_part_table.h, libblock/include/rtems/ramdisk.h: Add doxygen preamble.
* 2004-04-17 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-171-1/+1
| | | | | * libblock/src/ide_part_table.c: Use fprintf(stdout,...) instead of printf.
* Remove stray white spaces.Ralf Corsepius2004-04-179-103/+103
* Remove stray white spaces.Ralf Corsepius2004-04-158-148/+148
* 2004-04-09 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-091-1/+7
| | | | | * libblock/Makefile.am: Build libblock for !UNIX only. * libcsupport/Makefile.am: Build $(TERMIOS_C_FILES) for !UNIX only.
* 2004-04-09 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-091-2/+2
| | | | | * libblock/Makefile.am: Remove LIBC_DEFINES (Unsupported). * libfs/Makefile.am: Remove LIBC_DEFINES (Unsupported).
* 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-012-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libblock/include/rtems/bdbuf.h: Include <rtems/chain.h> instead of <chain.h>. * libblock/include/rtems/ide_part_table.h: Include <rtems/chain.h> instead of <chain.h>. * libcsupport/src/malloc.c: Include <rtems/chain.h> instead of <chain.h>. * libcsupport/src/mount.c: Include <rtems/chain.h> instead of <chain.h>. * libcsupport/src/unmount.c: Include <rtems/chain.h> instead of <chain.h>. * libfs/src/imfs/imfs.h: Include <rtems/chain.h> instead of <chain.h>. * libfs/src/imfs/imfs_directory.c: Include <rtems/chain.h> instead of <chain.h>. * libfs/src/imfs/imfs_load_tar.c: Include <rtems/chain.h> instead of <chain.h>. * sapi/include/confdefs.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * sapi/include/confdefs.h: Include <rtems/console.h> instead of <console.h>. * libfs/src/imfs/imfs_load_tar.c: Include <rtems/imfs.h> instead of <imfs.h>. * libmisc/shell/cmds.c: Include <rtems/imfs.h> instead of <imfs.h>. * libmisc/fsmount/fsmount.c: Include <rtems/imfs.h> instead of <imfs.h>. * sapi/include/confdefs.h: Include <rtems/imfs.h> instead of <imfs.h>. * itron/src/can_wup.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/chg_pri.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/cre_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/cre_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/cre_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/cre_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/del_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/del_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/del_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/del_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/dis_dsp.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ena_dsp.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/eventflags.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/exd_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ext_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/fmempool.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/frsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/get_tid.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/itronintr.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/itronsem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/itrontime.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/mbox.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/mboxtranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/msgbuffer.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/msgbuffertranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/network.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/port.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/prcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/prcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/preq_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/psnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ref_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ref_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ref_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ref_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rel_wai.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rot_rdq.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/sig_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/slp_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/snd_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/snd_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/sta_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/sus_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/sysmgmt.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/task.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ter_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/trcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/trcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/tslp_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/tsnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/twai_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/vmempool.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/wai_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/wup_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * sapi/include/rtems/config.h: Include <rtems/itron.h> instead of <itron.h>. * sapi/include/confdefs.h: Include <rtems/itron.h> instead of <itron.h>. * sapi/src/itronapi.c: Include <rtems/itron.h> instead of <itron.h>. * sapi/include/confdefs.h: Include <rtems/rtc.h> instead of <rtc.h>. * sapi/include/confdefs.h: Include <rtems/timerdrv.h> instead of <timerdrv.h>.
* Unused.Ralf Corsepius2004-03-083-6/+0
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-051-1/+2
| | | | * libblock/src/bdbuf.c: Initialize pointer to avoid warning.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-8/+1
| | | | | | | | | | | | | | | | | | | | | * libblock/src/bdbuf.c, libblock/src/ramdisk.c, libcsupport/src/newlibc.c, libcsupport/src/sync.c, libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c, libmisc/shell/cmds.c, libmisc/shell/shell.c, libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c, libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c, libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c, libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c, libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c, libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c, libnetworking/libc/res_send.c, libnetworking/libc/res_update.c, libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c, librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c, score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too much was accidentally committed -- revert.
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-052-1/+8
| | | | | | | | | | | | | | | | | | | | | * libblock/src/bdbuf.c, libblock/src/ramdisk.c, libcsupport/src/newlibc.c, libcsupport/src/sync.c, libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c, libmisc/shell/cmds.c, libmisc/shell/shell.c, libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c, libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c, libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c, libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c, libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c, libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c, libnetworking/libc/res_send.c, libnetworking/libc/res_update.c, libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c, librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c, librpc/src/rpc/svc.c, sapi/include/confdefs.h, score/macros/rtems/score/chain.inl, score/src/objectidtoname.c:
* 2004-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-231-278/+0
| | | | | * ChangeLog: Merge-in libblock/ChangeLog, libfs/ChangeLog. * libblock/ChangeLog, libfs/ChangeLog: Remove.
* Cleanup ChangeLog.Ralf Corsepius2004-01-231-120/+90
* 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-192-1/+7
| | | | * Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-142-0/+8
| | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-13/+17
| | | | | * Makefile.am: Include compile.am, again. Eliminate C_FILES. Reformat.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-092-1/+8
| | | | | * Makefile.am: Add libs to CLEANFILES Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-096-34/+40
| | | | | | * include/rtems/blkdev.h, include/rtems/ide_part_table.h, src/bdbuf.c, src/ide_part_table.c, src/ramdisk.c: Switch to using c99 fixed size types instead of RTEMS-types.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-092-7/+12
| | | | | * Makefile.am: Build libblock$(LIB_VARIANT).a instead of $(ARCH)/libblock.a.
* 2004-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-072-12/+13
| | | | * Makefile.am: Build library using EXTRA_LIBRARIES and automake rules.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-2/+5
| | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-042-1321/+4
| | | | * src/ata.c: Remove.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-012-2/+6
| | | | * Makefile.am: Add $(dirstamp) to compilation rules.
