path: root/cpukit/libblock/src/show_bdbuf.c (follow)
* libblock: Doxygen Enhancement Task #1Mathew Kallada2012-12-211-35/+25
* 2011-01-20 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-01-201-1/+1
| | | | | * libblock/src/show_bdbuf.c, score/src/objectmp.c: Avoid chain API violations.
* Whitespace removal.Ralf Corsepius2009-11-291-33/+33
* Convert to using "bool".Ralf Corsepius2008-09-011-52/+52
* 2008-01-23 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-01-231-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * itron/include/rtems/itron/object.h, itron/src/cre_tsk.c, libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c, libmisc/capture/capture.c, libmisc/monitor/mon-manager.c, libmisc/stackchk/check.c, posix/src/condinit.c, posix/src/keycreate.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c, posix/src/mqueueopen.c, posix/src/mqueueunlink.c, posix/src/mutexinit.c, posix/src/pbarrierinit.c, posix/src/prwlockinit.c, posix/src/pspininit.c, posix/src/pthreadcreate.c, posix/src/pthreadexit.c, posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c, posix/src/timercreate.c, rtems/src/barrierident.c, rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c, rtems/src/ratemonident.c, rtems/src/regionident.c, rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c, sapi/src/extensionident.c, score/Makefile.am, score/include/rtems/score/object.h, score/inline/rtems/score/object.inl, score/src/apimutexallocate.c, score/src/objectextendinformation.c, score/src/objectgetnameasstring.c, score/src/objectmp.c, score/src/objectnametoid.c: Convert the Objects_Name type from a simple type to a union of an unsigned 32 bit integer and a pointer. This should help eliminate weird casts between u32 and pointers in various places. The APIs now have to explicitly call _u32 or _string versions of helper routines. This should also simplify things and eliminate the need for ugly casts in some cases. * score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c: Removed.
* 2007-05-08 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-05-081-0/+5
| | | | * libblock/src/show_bdbuf.c: Add HAVE_CONFIG_H magic.
* 2007-01-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-01-301-11/+11
| | | | * libblock/src/show_bdbuf.c: Use inttypes.h macros.
* 2007-01-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-01-271-904/+904
| | | | * libblock/src/show_bdbuf.c: Convert from DOS to UNIX.
* mproved gen5200 MSCAN driverThomas Doerfler2007-01-211-0/+904
fixed synchronization bug between ata.c and bdbuf.c
