path: root/cpukit/libblock/src/blkdev-blkstats.c (follow)
* cpukit, testsuite: Add rtems_printf and rtems_printer support.Chris Johns2016-05-251-9/+8
| | | | | | | | | | | | | | | | | | | This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work.
* libblock: Print block sizes and countSebastian Huber2015-11-021-0/+10
* Include missing <string.h>Sebastian Huber2013-07-231-0/+1
* libblock: Doxygen Enhancement Task #1Mathew Kallada2012-12-211-0/+7
* libblock: Add block device statisticsSebastian Huber2012-06-121-0/+70
