Show the correct index of partition's last block (partition end).
The documentation of struct rtems_bdpart_partition (P) says that the member
'end' is the "Block index for partition end (this block is not a part of the
partition)". Then, the fdisk's partition table dump should print ((P)->end -
1).
Currently, one can think that the last block of a partition P is superposing
the beginning of the partition (P + 1). Example:
PARTITION TABLE
BEGIN | END | TYPE
2048 | 133120 | FAT 32
133120 | 15628032 | FAT 32
With be proposed patch, it would be:
PARTITION TABLE
BEGIN | END | TYPE
2048 | 133119 | FAT 32
133120 | 15628031 | FAT 32
* libblock/src/bdpart.c: Removed file.
* libblock/src/bdpart-create.c, libblock/src/bdpart-dump.c,
libblock/src/bdpart-mount.c, libblock/src/bdpart-read.c,
libblock/src/bdpart-register.c, libblock/src/bdpart-sort.c,
libblock/src/bdpart-write.c: New files.
* libblock/include/rtems/bdpart.h: Moved some definitions from bdpart.c.
* libblock/Makefile.am: Update for file changes.
