Use the PTHREAD mutexes and condition variables if available. This
helps on SMP configurations to avoid the home grown condition variables
via disabled preemption.
This helps to prevent stack overflows due to configuration errors.
This is the result of a sed script which converts all uses
of @{ into a consistent form.
Add and use rtems_blkdev_request_done(). Block device transfer requests
must signal the completion status now with rtems_blkdev_request_done().
The return value of the block device IO control will be ignored for
transfer requests.
The first parameter of rtems_blkdev_request_cb is now the transfer
request structure.
Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to
break third party drivers at compile time, otherwise this API change
would result in runtime errors.
The set block size must synchronize and purge the disk to avoid an
inconsistent cache state and data corruption. The synchronization is
optional depending on the new sync parameter. In some contexts a
synchronization must not be performed, e.g. during disk creation.
This allows addtion of per disk statistics for example.
Read-ahead requests were previously executed in the context of the
reading task. This blocks the reading task until the complete read
with read-ahead transfer is finished. A read-ahead task is introduced
to off-load the read-ahead transfer. This allows the reading task to
work with the requested block more quickly. The read-ahead is triggered
after two misses of ascending consecutive blocks or a read hit of a
block read by the most-recent read-ahead transfer. The read-ahead
feature is configurable and can be disabled.
Add block_count and media_blocks_per_block to rtems_disk_device. Add
and use rtems_disk_init_phys() and rtems_disk_init_log().
The task stack size for the swap-out and worker tasks is now
configurable. The bdbuf task resources are now included in the work
space size estimate.
The new function rtems_bdbuf_set_block_size() must be used to set the
block size of a disk device. It will check if the block size is valid
and set the new fields block_to_media_block_shift and bds_per_group of
the rtems_disk_device structure. This helps to avoid complex arithmetic
operations in the block device buffer get and read path.
Calling the bdbuf API functions in the not configured state is now a
fatal error.
New functions
o rtems_blkdev_create(), and
o rtems_blkdev_create_partition().
New test libtests/block11.
Add
o rtems_disk_get_block_size(),
o rtems_disk_get_block_begin(), and
o rtems_disk_get_block_count().
The functions
o rtems_bdbuf_get(),
o rtems_bdbuf_read(),
o rtems_bdbuf_syncdev(), and
o rtems_bdbuf_purge_dev(),
use now the disk device instead of the device identifier. This makes
bdbuf independent of rtems_disk_obtain() and rtems_disk_release(). It
is the responsiblity of the file system to obtain the disk device. This
also reduces the overhead to get a buffer.
The key for the AVL tree uses now the disk device instead of the device
identifier. The pointer is interpreted as an unsigned integer. This
reduces the memory overhead and makes the comparison operation a bit
faster.
Removed function rtems_bdbuf_purge_major(). This function was too
destructive and could have unpredictable side effects.
All these variables are protected by the bdbuf cache mutex.
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
* libblock/include/rtems/bdbuf.h: Documentation.
* libblock/include/rtems/bdpart.h (rtems_bdpart_format):
Preserve previous API.
* libblock/src/bdpart-create.c, libblock/src/bdpart-read.c,
libblock/src/bdpart-write.c: Reflect changes above.
* libmisc/shell/fdisk.c: Reflect changes above.
Eliminate unnamed union (Non c99-compliant).
* libblock/src/blkdev-ops.c: New file.
* libblock/Makefile.am: Reflect change from above.
* libblock/include/rtems/blkdev.h: Declare rtems_blkdev_generic_ops.
* libblock/include/rtems/media.h, libblock/src/media-server.c: Use
chains instead of a message queue.
* libblock/include/rtems/media.h, libblock/src/media-desc.c,
libblock/src/media-dev-ident.c, libblock/src/media-path.c,
libblock/src/media-server.c, libblock/src/media.c: New files.
* Makefile.am, preinstall.am, libblock/Makefile.am: Reflect changes
above.
* libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c,
libcsupport/src/__times.c, libcsupport/src/libio_init.c,
libcsupport/src/mallocfreespace.c, libcsupport/src/mount-mgr.c,
libcsupport/src/mount.c, libcsupport/src/rewinddir.c,
libcsupport/src/seekdir.c, libcsupport/src/telldir.c,
libcsupport/src/unmount.c, libfs/src/dosfs/fat.c,
libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_rename.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/shell/vis.c, libmisc/stackchk/check.c, sapi/src/posixapi.c,
telnetd/telnetd.c: Remove include of assert.h when it is not needed.
* libblock/include/rtems/nvdisk.h, libblock/src/nvdisk-sram.c:
Use pointer arithmetic instead of int32_t arithmetic for 16bit
compatibility.
* libblock/src/diskdevs.c, libblock/include/rtems/blkdev.h,
libblock/src/bdbuf.c: PR 1448/filesystem.
* libblock/include/rtems/blkdev.h, libblock/src/bdbuf.c: PR
1514/filesystem.
