path: root/cpukit/itron (follow)
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-0118-1/+819
| | | | | | | | | | | | | | | * Added macro support to ITRON API. This is known to compile. * Makefile.am: Added macros directory. * configure.in: Removed error check for enabling macros. * macros/.cvsignore, macros/Makefile.am, macros/rtems/.cvsignore, macros/rtems/Makefile.am, macros/rtems/itron/.cvsignore, macros/rtems/itron/Makefile.am, macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl, macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl, macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl, macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl, macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl, macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl: New files.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-1/+6
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+5
| | | | * src/Makefile.am: Include compile.am.
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-261-2/+6
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1210-32/+19
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-139-0/+29
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-081-1/+0
* POSIX message queues now include complete functionality includingJoel Sherrill2000-01-134-19/+19
| | | | | | | | | | | | | | | | blocking sends when the queue is full. The SuperCore was enhanced to support blocking on send. The existing POSIX API was debugged and numerous test cases were added to psxmsgq01 by Jennifer Averett. SuperCore enhancements and resulting modifications to other APIs were done by Joel. There is one significant point of interpretation for the POSIX API. What happens to threads already blocked on a message queue when the mode of that same message queue is changed from blocking to non-blocking? We decided to unblock all waiting tasks with an EAGAIN error just as if a non-blocking version of the same operation had returned unsatisfied. This case is not discussed in the POSIX standard and other implementations may have chosen differently.
* Added new message priority parameter as returned by core support routine.Joel Sherrill2000-01-051-5/+7
* Patch rtems-rc-19991117-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-0/+70
| | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-6/+6
* + Updated copyright information.Jennifer Averett1999-11-1799-2/+295
* Updated Mailbox Manager submitted and split into multiple files.Joel Sherrill1999-11-1711-344/+470
* Update from Andrew D. McDowell <amcdowel@cs.uah.edu> with modificationsJoel Sherrill1999-11-171-7/+257
| | | | | by Joel and Jennifer based on experience merging the other managers and cleaning them up. No test code is available at this point.
* Added check to return passed if task is not suspended.Jennifer Averett1999-11-162-1/+7
* Added code to catch the error of suspend count exceding the counter value.Jennifer Averett1999-11-161-0/+4
* Comment fixed when adding prototype forJoel Sherrill1999-11-161-2/+11
| | | | _ITRON_Message_buffer_Translate_core_message_buffer_return_code.
* Returned third parameter for a NULL name to the objects open call.Jennifer Averett1999-11-151-1/+1
* + Fixed files to consistantly use a case of the location after callsJennifer Averett1999-11-1511-81/+97
| | | | | | to ITRON_Task_Get. + Modified to consistantly call _ITRON_return_errorno with E_OK. + Optimized the code to not disable dispatch prior to checking input values.
* + Modified to use new Thread_Reset routine instead of the restart method.Jennifer Averett1999-11-151-1/+1
* Split ITRON Message Buffer Manager into multiple files.Joel Sherrill1999-11-1511-354/+521
* Split ITRON semaphore manager into multiple files.Joel Sherrill1999-11-158-284/+376
* + Changed validation of the_thread to validation of location.Joel Sherrill1999-11-124-37/+27
| | | | | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK.
* + Changed validation of the_thread to validation of location.Joel Sherrill1999-11-121-11/+11
| | | | + Removed error path that should never happen.
* + Changed validation of the_thread to validation of location.Joel Sherrill1999-11-122-17/+8
* + Moved error checks to before the disable dispatch where possible.Joel Sherrill1999-11-121-5/+5
* Added comment about the E_CTX error condition (Implementation dependent).Joel Sherrill1999-11-121-0/+7
* + Moved error checks to before the dispatch disable where possible.Joel Sherrill1999-11-121-13/+12
* + Modified correct return path to call _ITRON_return_errorno( E_OK ) insteadJoel Sherrill1999-11-121-15/+10
| | | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. + Set correct error code when dormant state. + Fixed comment.
* + Modified correct return path to call _ITRON_return_errorno( E_OK ) insteadJoel Sherrill1999-11-121-5/+2
* Removed unnecessary 3rd parameter.Joel Sherrill1999-11-121-1/+1
* New file.Joel Sherrill1999-11-121-0/+13
* Cleaned up style.Joel Sherrill1999-11-121-243/+239
* Removed redundant line.Joel Sherrill1999-11-121-1/+0
* Committed modifications from ITRON Task and Task Dependendent SynchronizationJoel Sherrill1999-11-1021-99/+365
| | | | Working Group. Included are tests.
* Commented out single letter type names since they conflict withJoel Sherrill1999-11-091-0/+6
| | | | numerous other uses of the same variable.
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-0979-0/+7420
for RTEMS.
