* src/Makefile.am: Include compile.am.
that contains:
* Removes MKLIB
handling)
were done by Joel.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
by Joel and Jennifer based on experience merging the other managers
and cleaning them up. No test code is available at this point.
_ITRON_Message_buffer_Translate_core_message_buffer_return_code.
to ITRON_Task_Get.
+ Modified to consistantly call _ITRON_return_errorno with E_OK.
+ Optimized the code to not disable dispatch prior to checking input values.
+ Modified correct return path to call _ITRON_return_errorno( E_OK ) instead
of enabling dispatching and returning E_OK.
+ Removed error path that should never happen.
+ Changed validation of the_thread to validation of location.
+ Set correct error code when dormant state.
+ Fixed comment.
numerous other uses of the same variable.
for RTEMS.
