* itron/src/task.c, posix/src/pthread.c, rtems/src/tasks.c,
sapi/src/exinit.c, score/include/rtems/score/apiext.h,
score/src/apiext.c: No APIs currently implemented use the
predriver_hook so disable it until such time as it is used.
* itron/include/rtems/itron/config.h,
itron/include/rtems/itron/eventflags.h,
itron/include/rtems/itron/fmempool.h,
itron/include/rtems/itron/mbox.h,
itron/include/rtems/itron/msgbuffer.h,
itron/include/rtems/itron/port.h,
itron/include/rtems/itron/semaphore.h,
itron/include/rtems/itron/task.h,
itron/include/rtems/itron/vmempool.h, itron/src/eventflags.c,
itron/src/fmempool.c, itron/src/itroninittasks.c,
itron/src/itronsem.c, itron/src/mbox.c, itron/src/msgbuffer.c,
itron/src/port.c, itron/src/task.c, itron/src/vmempool.c,
sapi/src/itronapi.c: Convert ITRON manager initialization routines to
directly pull parameters from configuration table.
* itron/src/chg_pri.c, itron/src/cre_tsk.c, itron/src/rot_rdq.c,
posix/Makefile.am, posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/priority.h, posix/src/mutex.c,
score/include/rtems/score/priority.h: Run all tests successfully with
maxixum number of priorities as 16 instead of 256. This was done by
temporarily modifying the score priority.h maximum. This allowed
testing of all API code to ensure that it worked properly with a
reduced number of priorities. Most modifications were to switch from
hard-coded maximum to using the SuperCore variable based upon
configured number.
* posix/src/mutexdefaultattributes.c: Removed.
* itron/include/rtems/itron/task.h, itron/src/def_cyc.c,
itron/src/task.c, libcsupport/src/newlibc_exit.c,
libcsupport/src/sync.c, libfs/src/imfs/imfs_fchmod.c,
posix/include/rtems/posix/pthread.h, posix/src/pthread.c,
posix/src/sysconf.c, rtems/include/rtems/rtems/tasks.h,
rtems/src/tasks.c, score/include/rtems/score/stack.h,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl, score/src/threadhandler.c: Fix
various nested-externs warnings.
PR 1291/cpukit
* itron/inline/rtems/itron/semaphore.inl, itron/src/twai_sem.c,
posix/include/mqueue.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/time.h, posix/src/condtimedwait.c,
posix/src/mqueuereceive.c, posix/src/mqueuerecvsupp.c,
posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c,
posix/src/mutextimedlock.c, posix/src/mutextranslatereturncode.c,
posix/src/posixtimespecabsolutetimeout.c,
posix/src/semaphoretranslatereturncode.c,
posix/src/semaphorewaitsupp.c, posix/src/semtimedwait.c,
posix/src/semtrywait.c, posix/src/semwait.c,
posix/src/sigtimedwait.c, posix/src/timersettime.c,
posix/src/ualarm.c, rtems/src/semobtain.c,
rtems/src/semtranslatereturncode.c,
score/include/rtems/score/coresem.h, score/src/coresemseize.c: This
patch addresses issues on implementation of the timeout on the
following POSIX services. Some of these services incorrectly took a
timeout as a relative time. Others would compute a 0 delta to timeout
if the absolute time and the current time were equal and thus
incorrectly block the caller forever. The root of the confusion is
that POSIX specifies that if the timeout is incorrect (e.g. in the
past, is now, or is numerically invalid), that it does not matter if
the call would succeed without blocking. This is in contrast to RTEMS
programming style where all errors are checked before any critical
sections are entered. This fix implemented a more uniform way of
handling POSIX absolute time timeouts.
+ pthread_cond_timedwait - could block forever
+ mq_timedreceive - used relative not absolute time
+ mq_timedsend - used relative not absolute time
+ pthread_mutex_timedlock - used relative not absolute time
+ pthread_rwlock_timedrdlock- used relative not absolute time
+ pthread_rwlock_timedwrlock- used relative not absolute time
+ sem_timedwait - could block forever
* itron/include/rtems/itron/task.h, itron/src/task.c: ITRON currently
has no functional data in the user extension data area structure so
this disables the definition, allocation and deallocation of that
structure. If we ever have to add data to it, then it will be easy to
reenable.
* itron/include/rtems/itron/task.h, itron/src/del_tsk.c,
itron/src/exd_tsk.c, itron/src/task.c,
posix/include/rtems/posix/threadsup.h, posix/src/cancel.c,
posix/src/cancelrun.c, posix/src/pthread.c, posix/src/pthreadexit.c,
posix/src/setcancelstate.c, posix/src/setcanceltype.c,
posix/src/testcancel.c, rtems/src/taskdelete.c,
score/inline/rtems/score/object.inl, score/src/objectclose.c,
score/src/threadclose.c: Make all task delete/exit/cancel routines
follow the same critical section pattern. Also ensure that POSIX
cancelation routines are run at thread exit.
* itron/include/rtems/itron/task.h, itron/src/cre_tsk.c,
posix/src/pthreadcreate.c, rtems/src/taskcreate.c,
rtems/src/taskdelete.c, rtems/src/timerserver.c,
score/src/threadclose.c, score/src/threadcreateidle.c,
score/src/threadinitialize.c: Switch task create and delete
operations to using API Allocator Mutex. This moves almost all uses
of the RTEMS Workspace from dispatching disabled to mutex protected
which should improve deterministic behavior. The implementation was
carefully done to allow task create and delete extensions to invoke
more services. In particular, a task delete extension should be able
to do mutex and file operations.
* itron/src/exd_tsk.c, itron/src/task.c, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-symbols.c, posix/src/cancelrun.c,
posix/src/pthreadexit.c, rtems/Makefile.am, rtems/preinstall.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/support.h,
rtems/inline/rtems/rtems/tasks.inl, rtems/src/eventmp.c,
rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c,
rtems/src/rtemsobjectgetname.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskdelete.c, rtems/src/taskmp.c,
rtems/src/timerserver.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/Unlimited.txt,
score/src/objectgetnameasstring.c,
score/src/threadqextractwithproxy.c: Add new Object Services
collection. This changed the name of a few previously public but
undocumented services and added a some new services.
* rtems/include/rtems/rtems/object.h, rtems/src/rtemsbuildid.c,
rtems/src/rtemsbuildname.c, rtems/src/rtemsobjectapimaximumclass.c,
rtems/src/rtemsobjectapiminimumclass.c,
rtems/src/rtemsobjectgetapiclassname.c,
rtems/src/rtemsobjectgetapiname.c,
rtems/src/rtemsobjectgetclassicname.c,
rtems/src/rtemsobjectgetclassinfo.c,
rtems/src/rtemsobjectidapimaximum.c,
rtems/src/rtemsobjectidapiminimum.c, rtems/src/rtemsobjectidgetapi.c,
rtems/src/rtemsobjectidgetclass.c, rtems/src/rtemsobjectidgetindex.c,
rtems/src/rtemsobjectidgetnode.c, rtems/src/rtemsobjectsetname.c,
score/src/objectapimaximumclass.c, score/src/objectgetinfo.c,
score/src/objectgetinfoid.c, score/src/objectsetname.c: New files.
* rtems/src/rtemsidtoname.c: Removed.
* itron/include/rtems/itron/object.h, itron/src/cre_tsk.c,
libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c,
libmisc/capture/capture.c, libmisc/monitor/mon-manager.c,
libmisc/stackchk/check.c, posix/src/condinit.c,
posix/src/keycreate.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c,
posix/src/mqueueopen.c, posix/src/mqueueunlink.c,
posix/src/mutexinit.c, posix/src/pbarrierinit.c,
posix/src/prwlockinit.c, posix/src/pspininit.c,
posix/src/pthreadcreate.c, posix/src/pthreadexit.c,
posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c,
posix/src/timercreate.c, rtems/src/barrierident.c,
rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c,
rtems/src/ratemonident.c, rtems/src/regionident.c,
rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c,
sapi/src/extensionident.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/apimutexallocate.c,
score/src/objectextendinformation.c,
score/src/objectgetnameasstring.c, score/src/objectmp.c,
score/src/objectnametoid.c: Convert the Objects_Name type from a
* score/src/objectclearname.c, score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c: Removed.
* itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c,
itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c,
itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c,
itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c,
itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c,
itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c,
itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c,
itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c,
posix/src/condinit.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mutexinit.c, posix/src/mutexlocksupp.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c,
posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c,
posix/src/pspindestroy.c, posix/src/pspinlock.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/barrierdelete.c, rtems/src/barrierrelease.c,
rtems/src/barrierwait.c, rtems/src/dpmemdelete.c,
rtems/src/dpmemexternal2internal.c,
rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c,
rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c,
rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c,
rtems/src/ratemontimeout.c, rtems/src/regiondelete.c,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/regionreturnsegment.c, rtems/src/semdelete.c,
rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c,
rtems/src/signalsend.c, rtems/src/taskdelete.c,
rtems/src/taskgetnote.c, rtems/src/taskissuspended.c,
rtems/src/taskrestart.c, rtems/src/taskresume.c,
rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c,
rtems/src/taskvariableget.c, rtems/src/timercancel.c,
rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c,
score/include/rtems/score/object.h, score/src/corerwlocktimeout.c,
score/src/mpci.c, score/src/objectgetnameasstring.c,
score/src/threaddelayended.c, score/src/threadqtimeout.c: When
multiprocessing is disabled, do not even allow the constant
OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of
a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results
in the generation of binary code which can NOT be reached.
* itron/Makefile.am, itron/src/eventflags.c, itron/src/fmempool.c,
itron/src/itronintr.c, itron/src/itrontime.c, itron/src/network.c,
itron/src/port.c, itron/src/sysmgmt.c, itron/src/task.c,
itron/src/vmempool.c, posix/Makefile.am, posix/src/pthread.c,
rtems/src/taskinitusers.c, rtems/src/tasks.c,
sapi/include/confdefs.h, sapi/src/io.c: Various modification to
reduce executable size. Most were refactoring of files. Split ITRON
API files. Implemented mechanism to avoid initialization task/thread
loop being linked in when that style of task initialization was not
being used.
* itron/src/acp_por.c, itron/src/act_cyc.c, itron/src/cal_por.c,
itron/src/chg_iXX.c, itron/src/clr_flg.c, itron/src/cre_flg.c,
itron/src/cre_mpf.c, itron/src/cre_mpl.c, itron/src/cre_por.c,
itron/src/def_alm.c, itron/src/def_cyc.c, itron/src/def_exc.c,
itron/src/def_int.c, itron/src/def_svc.c, itron/src/del_flg.c,
itron/src/del_mpf.c, itron/src/del_mpl.c, itron/src/del_por.c,
itron/src/dis_int.c, itron/src/dly_tsk.c, itron/src/ena_int.c,
itron/src/fwd_por.c, itron/src/get_blf.c, itron/src/get_blk.c,
itron/src/get_tim.c, itron/src/get_ver.c, itron/src/itroninittasks.c,
itron/src/loc_cpu.c, itron/src/nget_nod.c, itron/src/nget_ver.c,
itron/src/nrea_dat.c, itron/src/nwri_dat.c, itron/src/pacp_por.c,
itron/src/pcal_por.c, itron/src/pget_blf.c, itron/src/pget_blk.c,
itron/src/pol_flg.c, itron/src/ref_alm.c, itron/src/ref_cfg.c,
itron/src/ref_cyc.c, itron/src/ref_flg.c, itron/src/ref_iXX.c,
itron/src/ref_mpf.c, itron/src/ref_mpl.c, itron/src/ref_por.c,
itron/src/ref_sys.c, itron/src/rel_blf.c, itron/src/rel_blk.c,
itron/src/ret_int.c, itron/src/ret_tmr.c, itron/src/ret_wup.c,
itron/src/rpl_rdv.c, itron/src/set_flg.c, itron/src/set_tim.c,
itron/src/tacp_por.c, itron/src/tcal_por.c, itron/src/tget_blf.c,
itron/src/tget_blk.c, itron/src/twai_flg.c, itron/src/unl_cpu.c,
itron/src/wai_flg.c, posix/src/pthreadinitthreads.c: New files.
* itron/src/rsm_tsk.c: Correct error returned.
* itron/src/itrontime.c: Fix typo.
* score/include/rtems/score/tod.h: Add TOD_TICKS_PER_SECOND macro.
* score/src/iterateoverthreads.c: Safely take NULL as argument.
* score/src/threaddispatch.c: Formatting.
* itron/src/itrontime.c, libcsupport/src/__gettod.c,
posix/src/clockgettime.c, posix/src/clocksettime.c,
posix/src/nanosleep.c, posix/src/posixtimespecsubtract.c,
posix/src/posixtimespectointerval.c, posix/src/ptimer1.c,
posix/src/sleep.c, rtems/Makefile.am,
rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/timer.h,
rtems/include/rtems/rtems/types.h, rtems/src/clockget.c,
rtems/src/clockset.c, rtems/src/clocktodtoseconds.c,
rtems/src/clocktodvalidate.c, rtems/src/taskwakewhen.c,
score/Makefile.am, score/include/rtems/score/tod.h,
score/inline/rtems/score/tod.inl, score/src/coretod.c,
score/src/coretodset.c: Convert from Classic API style TOD_Control as
fundamental time structure to POSIX struct timespec. Add
clock_get_uptime().
* rtems/src/clockgetuptime.c, score/src/coretodget.c,
score/src/coretodgetuptime.c: New files.
* score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c: Removed.
PR 841/rtems
posix/src/semwait.c, rtems/src/semobtain.c,
score/include/rtems/score/coresem.h, score/src/coresemseize.c: Make
sem_timedwait more conformant to Open Group specification.
* itron/src/trcv_mbf.c, posix/src/semopen.c,
rtems/src/taskvariableadd.c, score/macros/rtems/score/heap.inl: Fix
warnings.
* libblock/include/rtems/bdbuf.h: Include <rtems/chain.h> instead of <chain.h>.
* libblock/include/rtems/ide_part_table.h: Include <rtems/chain.h> instead of <chain.h>.
* libcsupport/src/malloc.c: Include <rtems/chain.h> instead of <chain.h>.
* libcsupport/src/mount.c: Include <rtems/chain.h> instead of <chain.h>.
* libcsupport/src/unmount.c: Include <rtems/chain.h> instead of <chain.h>.
* libfs/src/imfs/imfs.h: Include <rtems/chain.h> instead of <chain.h>.
* libfs/src/imfs/imfs_directory.c: Include <rtems/chain.h> instead of <chain.h>.
* libfs/src/imfs/imfs_load_tar.c: Include <rtems/chain.h> instead of <chain.h>.
* sapi/include/confdefs.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>.
* sapi/include/confdefs.h: Include <rtems/console.h> instead of <console.h>.
* libfs/src/imfs/imfs_load_tar.c: Include <rtems/imfs.h> instead of <imfs.h>.
* libmisc/shell/cmds.c: Include <rtems/imfs.h> instead of <imfs.h>.
* libmisc/fsmount/fsmount.c: Include <rtems/imfs.h> instead of <imfs.h>.
* sapi/include/confdefs.h: Include <rtems/imfs.h> instead of <imfs.h>.
* itron/src/can_wup.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/chg_pri.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/dis_dsp.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ena_dsp.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/eventflags.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/exd_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ext_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/fmempool.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/frsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/get_tid.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/itronintr.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/itronsem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/itrontime.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/mbox.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/mboxtranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/msgbuffer.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/msgbuffertranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/network.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/port.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/prcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/prcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/preq_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/psnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rel_wai.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rot_rdq.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sig_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/slp_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/snd_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/snd_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sta_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sus_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sysmgmt.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/task.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ter_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/trcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/trcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/tslp_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/tsnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/twai_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/vmempool.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/wai_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/wup_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* sapi/include/rtems/config.h: Include <rtems/itron.h> instead of <itron.h>.
* sapi/include/confdefs.h: Include <rtems/itron.h> instead of <itron.h>.
* sapi/src/itronapi.c: Include <rtems/itron.h> instead of <itron.h>.
* sapi/include/confdefs.h: Include <rtems/rtc.h> instead of <rtc.h>.
* sapi/include/confdefs.h: Include <rtems/timerdrv.h> instead of <timerdrv.h>.
* itron/include/itronsys/mbox.h, itron/include/itronsys/types.h,
itron/macros/rtems/itron/semaphore.inl, itron/src/eventflags.c,
itron/src/fmempool.c, itron/src/itronsem.c, itron/src/mbox.c,
itron/src/msgbuffer.c, itron/src/port.c, itron/src/snd_mbx.c,
itron/src/task.c, itron/src/trcv_mbx.c, itron/src/vmempool.c:
Convert to using c99 fixed size types.
* src/config.h: Remove.
* Makefile.am: Remove src/config.h
AM_CPPFLAGS += -I$(top_builddir).
* include/itron.h, include/itronsys/eventflags.h,
include/itronsys/fmempool.h, include/itronsys/intr.h,
include/itronsys/mbox.h, include/itronsys/msgbuffer.h,
include/itronsys/network.h, include/itronsys/port.h,
include/itronsys/semaphore.h, include/itronsys/status.h,
include/itronsys/sysmgmt.h, include/itronsys/task.h,
include/itronsys/time.h, include/itronsys/types.h,
include/itronsys/vmempool.h, include/rtems/itron/config.h,
include/rtems/itron/eventflags.h, include/rtems/itron/fmempool.h,
include/rtems/itron/intr.h, include/rtems/itron/itronapi.h,
include/rtems/itron/mbox.h, include/rtems/itron/msgbuffer.h,
include/rtems/itron/network.h, include/rtems/itron/object.h,
include/rtems/itron/port.h, include/rtems/itron/semaphore.h,
include/rtems/itron/sysmgmt.h, include/rtems/itron/task.h,
include/rtems/itron/time.h, include/rtems/itron/vmempool.h,
inline/rtems/itron/eventflags.inl, inline/rtems/itron/fmempool.inl,
inline/rtems/itron/intr.inl, inline/rtems/itron/mbox.inl,
inline/rtems/itron/msgbuffer.inl, inline/rtems/itron/network.inl,
inline/rtems/itron/port.inl, inline/rtems/itron/semaphore.inl,
inline/rtems/itron/sysmgmt.inl, inline/rtems/itron/task.inl,
inline/rtems/itron/time.inl, inline/rtems/itron/vmempool.inl,
macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl,
macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl,
macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl,
macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl,
macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl,
macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl,
src/can_wup.c, src/chg_pri.c, src/cre_mbf.c, src/cre_mbx.c,
src/cre_sem.c, src/cre_tsk.c, src/del_mbf.c, src/del_mbx.c,
src/del_sem.c, src/del_tsk.c, src/dis_dsp.c, src/ena_dsp.c,
src/eventflags.c, src/exd_tsk.c, src/ext_tsk.c, src/fmempool.c,
src/frsm_tsk.c, src/get_tid.c, src/itronintr.c, src/itronsem.c,
src/itrontime.c, src/mbox.c, src/mboxtranslatereturncode.c,
src/msgbuffer.c, src/msgbuffertranslatereturncode.c, src/network.c,
src/port.c, src/prcv_mbf.c, src/prcv_mbx.c, src/preq_sem.c,
src/psnd_mbf.c, src/rcv_mbf.c, src/rcv_mbx.c, src/ref_mbf.c,
src/ref_mbx.c, src/ref_sem.c, src/ref_tsk.c, src/rel_wai.c,
src/rot_rdq.c, src/rsm_tsk.c, src/sig_sem.c, src/slp_tsk.c,
src/snd_mbf.c, src/snd_mbx.c, src/sta_tsk.c, src/sus_tsk.c,
src/sysmgmt.c, src/task.c, src/ter_tsk.c, src/trcv_mbf.c,
src/trcv_mbx.c, src/tslp_tsk.c, src/tsnd_mbf.c, src/twai_sem.c,
src/vmempool.c, src/wai_sem.c, src/wup_tsk.c: URL for license
changed.
* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am:
* src/config.h: New.
* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* src/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES.
* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* src/cre_mbf.c, src/cre_sem.c, src/eventflags.c, src/fmempool.c,
src/itronsem.c, src/mbox.c, src/msgbuffer.c, src/port.c, src/task.c,
src/vmempool.c: Modified as part of above.
* configure.ac: Remove references to RTEMS_BSP.
* src/Makefile.am: Add libitron.a.
Use ../aclocal.
* inline/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* macros/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/task.c (_ITRON_Task_User_extensions): Add new fields to
be correct in respect to newly added fields for separate switch list.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/Makefile.am: Add multilib support.
* src/Makefile.am: Revamp INCLUDES handling to make automake-1.5
* src/snd_mbx.c, src/tsnd_mbf.c: Unblocking message queue operations
should NOT use _Thread_Executing for return status since it is
permissible to invoke message send operations from an ISR. This was
reported by Suvrat Gupta <suvrat@utstar.com>.
* src/Makefile.am: Include compile.am.
that contains:
* Removes MKLIB
handling)
were done by Joel.
