path: root/cpukit/itron/src (unfollow)
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
2001-12-192001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* src/Makefile.am: Add multilib support.
2001-09-242001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* src/Makefile.am: Revamp INCLUDES handling to make automake-1.5
2001-08-092001-08-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-6/+6
* src/snd_mbx.c, src/tsnd_mbf.c: Unblocking message queue operations should NOT use _Thread_Executing for return status since it is permissible to invoke message send operations from an ISR. This was reported by Suvrat Gupta <suvrat@utstar.com>.
2001-01-242001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill59-0/+234
* configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+1
* src/Makefile.am: Include compile.am.
2000-07-26Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill1-2/+6
a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill9-26/+16
2000-04-13Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1-0/+2
2000-02-08Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
that contains: * Removes remaining (now illegal) references to $(SRC) from a couple of Makefile.ams * Removes duplicate AC_CONFIG_SUBDIRS macro from c/configure.in * Moves ENABLE_LIBCDIR into RTEMS_PROG_C[C|XX]_FOR_TARGET (hides LIBCDIR from most configure scripts, i.e. LIBCDIR becomes less visible) * Adds RTEMS_PROG_C[C|XX]_FOR_TARGET and RTEMS_CANONICALIZE_TOOLS to libbsp/*/configure.ins (A minor bug in previous implementations, which only has an impact when switching to GNU/Cygnus canonicalization) * Cleans up several bogus comments. * Removes MKLIB * Switches the version number to 4.5.0 (for testing version number handling)
2000-01-13POSIX message queues now include complete functionality includingJoel Sherrill4-19/+19
blocking sends when the queue is full. The SuperCore was enhanced to support blocking on send. The existing POSIX API was debugged and numerous test cases were added to psxmsgq01 by Jennifer Averett. SuperCore enhancements and resulting modifications to other APIs were done by Joel. There is one significant point of interpretation for the POSIX API. What happens to threads already blocked on a message queue when the mode of that same message queue is changed from blocking to non-blocking? We decided to unblock all waiting tasks with an EAGAIN error just as if a non-blocking version of the same operation had returned unsatisfied. This case is not discussed in the POSIX standard and other implementations may have chosen differently.
2000-01-05Added new message priority parameter as returned by core support routine.Joel Sherrill1-5/+7
1999-11-23Patch rtems-rc-19991117-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+70
to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
1999-11-17+ Updated copyright information.Jennifer Averett57-0/+171
1999-11-17Updated Mailbox Manager submitted and split into multiple files.Joel Sherrill9-332/+442
1999-11-17Update from Andrew D. McDowell <amcdowel@cs.uah.edu> with modificationsJoel Sherrill1-7/+257
by Joel and Jennifer based on experience merging the other managers and cleaning them up. No test code is available at this point.
1999-11-16Added check to return passed if task is not suspended.Jennifer Averett2-1/+7
1999-11-16Added code to catch the error of suspend count exceding the counter value.Jennifer Averett1-0/+4
1999-11-15+ Fixed files to consistantly use a case of the location after callsJennifer Averett11-81/+97
to ITRON_Task_Get. + Modified to consistantly call _ITRON_return_errorno with E_OK. + Optimized the code to not disable dispatch prior to checking input values.
1999-11-15+ Modified to use new Thread_Reset routine instead of the restart method.Jennifer Averett1-1/+1
1999-11-15Split ITRON Message Buffer Manager into multiple files.Joel Sherrill11-354/+521
1999-11-15Split ITRON semaphore manager into multiple files.Joel Sherrill8-284/+376
1999-11-12+ Changed validation of the_thread to validation of location.Joel Sherrill4-37/+27
+ Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK.
1999-11-12+ Changed validation of the_thread to validation of location.Joel Sherrill1-11/+11
+ Removed error path that should never happen.
1999-11-12+ Changed validation of the_thread to validation of location.Joel Sherrill2-17/+8
1999-11-12+ Moved error checks to before the disable dispatch where possible.Joel Sherrill1-5/+5
1999-11-12Added comment about the E_CTX error condition (Implementation dependent).Joel Sherrill1-0/+7
1999-11-12+ Moved error checks to before the dispatch disable where possible.Joel Sherrill1-13/+12
1999-11-12+ Modified correct return path to call _ITRON_return_errorno( E_OK ) insteadJoel Sherrill1-15/+10
of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. + Set correct error code when dormant state. + Fixed comment.
1999-11-12+ Modified correct return path to call _ITRON_return_errorno( E_OK ) insteadJoel Sherrill1-5/+2
1999-11-12New file.Joel Sherrill1-0/+13
1999-11-12Cleaned up style.Joel Sherrill1-243/+239
1999-11-12Removed redundant line.Joel Sherrill1-1/+0
1999-11-10Committed modifications from ITRON Task and Task Dependendent SynchronizationJoel Sherrill17-91/+330
1999-11-09This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill32-0/+2992
for RTEMS.
