* | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-24 | 1 | -0/+4 |
| | | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support. | ||||
* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 1 | -0/+3 |
* | Added check to return passed if task is not suspended. | Jennifer Averett | 1999-11-16 | 1 | -0/+3 |
* | + Fixed files to consistantly use a case of the location after calls | Jennifer Averett | 1999-11-15 | 1 | -3/+3 |
| | | | | | | to ITRON_Task_Get. + Modified to consistantly call _ITRON_return_errorno with E_OK. + Optimized the code to not disable dispatch prior to checking input values. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 1 | -12/+8 |
| | | | | | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK. | ||||
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-10 | 1 | -1/+26 |
| | | | | Working Group. Included are tests. | ||||
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 1 | -0/+31 |
for RTEMS. |
