| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/itron.h, include/itronsys/eventflags.h, include/itronsys/fmempool.h, include/itronsys/intr.h, include/itronsys/mbox.h, include/itronsys/msgbuffer.h, include/itronsys/network.h, include/itronsys/port.h, include/itronsys/semaphore.h, include/itronsys/status.h, include/itronsys/sysmgmt.h, include/itronsys/task.h, include/itronsys/time.h, include/itronsys/types.h, include/itronsys/vmempool.h, include/rtems/itron/config.h, include/rtems/itron/eventflags.h, include/rtems/itron/fmempool.h, include/rtems/itron/intr.h, include/rtems/itron/itronapi.h, include/rtems/itron/mbox.h, include/rtems/itron/msgbuffer.h, include/rtems/itron/network.h, include/rtems/itron/object.h, include/rtems/itron/port.h, include/rtems/itron/semaphore.h, include/rtems/itron/sysmgmt.h, include/rtems/itron/task.h, include/rtems/itron/time.h, include/rtems/itron/vmempool.h, inline/rtems/itron/eventflags.inl, inline/rtems/itron/fmempool.inl, inline/rtems/itron/intr.inl, inline/rtems/itron/mbox.inl, inline/rtems/itron/msgbuffer.inl, inline/rtems/itron/network.inl, inline/rtems/itron/port.inl, inline/rtems/itron/semaphore.inl, inline/rtems/itron/sysmgmt.inl, inline/rtems/itron/task.inl, inline/rtems/itron/time.inl, inline/rtems/itron/vmempool.inl, macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl, macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl, macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl, macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl, macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl, macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl, src/can_wup.c, src/chg_pri.c, src/cre_mbf.c, src/cre_mbx.c, src/cre_sem.c, src/cre_tsk.c, src/del_mbf.c, src/del_mbx.c, src/del_sem.c, src/del_tsk.c, src/dis_dsp.c, src/ena_dsp.c, src/eventflags.c, src/exd_tsk.c, src/ext_tsk.c, src/fmempool.c, src/frsm_tsk.c, src/get_tid.c, src/itronintr.c, src/itronsem.c, src/itrontime.c, src/mbox.c, src/mboxtranslatereturncode.c, src/msgbuffer.c, src/msgbuffertranslatereturncode.c, src/network.c, src/port.c, src/prcv_mbf.c, src/prcv_mbx.c, src/preq_sem.c, src/psnd_mbf.c, src/rcv_mbf.c, src/rcv_mbx.c, src/ref_mbf.c, src/ref_mbx.c, src/ref_sem.c, src/ref_tsk.c, src/rel_wai.c, src/rot_rdq.c, src/rsm_tsk.c, src/sig_sem.c, src/slp_tsk.c, src/snd_mbf.c, src/snd_mbx.c, src/sta_tsk.c, src/sus_tsk.c, src/sysmgmt.c, src/task.c, src/ter_tsk.c, src/trcv_mbf.c, src/trcv_mbx.c, src/tslp_tsk.c, src/tsnd_mbf.c, src/twai_sem.c, src/vmempool.c, src/wai_sem.c, src/wup_tsk.c: URL for license changed. | ||||
* | 2002-07-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-01 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * src/cre_mbf.c, src/cre_sem.c, src/eventflags.c, src/fmempool.c, src/itronsem.c, src/mbox.c, src/msgbuffer.c, src/port.c, src/task.c, src/vmempool.c: Modified as part of above. | ||||
* | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-24 | 1 | -0/+4 |
| | | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support. | ||||
* | POSIX message queues now include complete functionality including | Joel Sherrill | 2000-01-13 | 1 | -6/+4 |
| | | | | | | | | | | | | | | | | blocking sends when the queue is full. The SuperCore was enhanced to support blocking on send. The existing POSIX API was debugged and numerous test cases were added to psxmsgq01 by Jennifer Averett. SuperCore enhancements and resulting modifications to other APIs were done by Joel. There is one significant point of interpretation for the POSIX API. What happens to threads already blocked on a message queue when the mode of that same message queue is changed from blocking to non-blocking? We decided to unblock all waiting tasks with an EAGAIN error just as if a non-blocking version of the same operation had returned unsatisfied. This case is not discussed in the POSIX standard and other implementations may have chosen differently. | ||||
* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 1 | -0/+3 |
* | Split ITRON Message Buffer Manager into multiple files. | Joel Sherrill | 1999-11-15 | 1 | -0/+86 |
