path: root/cpukit/itron/macros (follow)
* Add doxygen preamble.Ralf Corsepius2004-11-2112-0/+48
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-231-1/+1
| | | | | | | | | | | | | | | | | | * itron/include/itronsys/mbox.h, itron/include/itronsys/types.h, itron/include/rtems/itron/eventflags.h, itron/include/rtems/itron/fmempool.h, itron/include/rtems/itron/mbox.h, itron/include/rtems/itron/msgbuffer.h, itron/include/rtems/itron/port.h, itron/include/rtems/itron/semaphore.h, itron/include/rtems/itron/task.h, itron/include/rtems/itron/vmempool.h, itron/inline/rtems/itron/semaphore.inl, itron/macros/rtems/itron/semaphore.inl, itron/src/eventflags.c, itron/src/fmempool.c, itron/src/itronsem.c, itron/src/mbox.c, itron/src/msgbuffer.c, itron/src/port.c, itron/src/snd_mbx.c, itron/src/task.c, itron/src/trcv_mbx.c, itron/src/vmempool.c: Convert to using c99 fixed size types.
* Unused.Ralf Corsepius2004-03-083-6/+0
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0412-12/+12
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/itron.h, include/itronsys/eventflags.h, include/itronsys/fmempool.h, include/itronsys/intr.h, include/itronsys/mbox.h, include/itronsys/msgbuffer.h, include/itronsys/network.h, include/itronsys/port.h, include/itronsys/semaphore.h, include/itronsys/status.h, include/itronsys/sysmgmt.h, include/itronsys/task.h, include/itronsys/time.h, include/itronsys/types.h, include/itronsys/vmempool.h, include/rtems/itron/config.h, include/rtems/itron/eventflags.h, include/rtems/itron/fmempool.h, include/rtems/itron/intr.h, include/rtems/itron/itronapi.h, include/rtems/itron/mbox.h, include/rtems/itron/msgbuffer.h, include/rtems/itron/network.h, include/rtems/itron/object.h, include/rtems/itron/port.h, include/rtems/itron/semaphore.h, include/rtems/itron/sysmgmt.h, include/rtems/itron/task.h, include/rtems/itron/time.h, include/rtems/itron/vmempool.h, inline/rtems/itron/eventflags.inl, inline/rtems/itron/fmempool.inl, inline/rtems/itron/intr.inl, inline/rtems/itron/mbox.inl, inline/rtems/itron/msgbuffer.inl, inline/rtems/itron/network.inl, inline/rtems/itron/port.inl, inline/rtems/itron/semaphore.inl, inline/rtems/itron/sysmgmt.inl, inline/rtems/itron/task.inl, inline/rtems/itron/time.inl, inline/rtems/itron/vmempool.inl, macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl, macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl, macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl, macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl, macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl, macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl, src/can_wup.c, src/chg_pri.c, src/cre_mbf.c, src/cre_mbx.c, src/cre_sem.c, src/cre_tsk.c, src/del_mbf.c, src/del_mbx.c, src/del_sem.c, src/del_tsk.c, src/dis_dsp.c, src/ena_dsp.c, src/eventflags.c, src/exd_tsk.c, src/ext_tsk.c, src/fmempool.c, src/frsm_tsk.c, src/get_tid.c, src/itronintr.c, src/itronsem.c, src/itrontime.c, src/mbox.c, src/mboxtranslatereturncode.c, src/msgbuffer.c, src/msgbuffertranslatereturncode.c, src/network.c, src/port.c, src/prcv_mbf.c, src/prcv_mbx.c, src/preq_sem.c, src/psnd_mbf.c, src/rcv_mbf.c, src/rcv_mbx.c, src/ref_mbf.c, src/ref_mbx.c, src/ref_sem.c, src/ref_tsk.c, src/rel_wai.c, src/rot_rdq.c, src/rsm_tsk.c, src/sig_sem.c, src/slp_tsk.c, src/snd_mbf.c, src/snd_mbx.c, src/sta_tsk.c, src/sus_tsk.c, src/sysmgmt.c, src/task.c, src/ter_tsk.c, src/trcv_mbf.c, src/trcv_mbx.c, src/tslp_tsk.c, src/tsnd_mbf.c, src/twai_sem.c, src/vmempool.c, src/wai_sem.c, src/wup_tsk.c: URL for license changed.
* 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-091-26/+0
| | | | | | | | | * include/Makefile.am: Remove. * inline/Makefile.am: Remove. * macros/Makefile.am: Remove. * src/Makefile.am: Remove. * Makefile.am: Merge-in removed Makefile.ams. * configure.ac: Reflect changes above.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-171-1/+1
| | | | | | | | | * include/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * inline/Makefile.am: Include $(top_srcdir)/../automake/*.am. * macros/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am.
| | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-161-3/+20
| | | | | | | | | | | | | | * include/itronsys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/rtems/itron/Makefile.am: Remove. * inline/rtems/Makefile.am: Remove. * inline/rtems/itron/Makefile.am: Remove. * macros/rtems/Makefile.am: Remove. * macros/rtems/itron/Makefile.am: Remove. * include/Makefile.am: handle subdirs. * inline/Makefile.am: handle subdirs. * macros/Makefile.am: handle subdirs. * configure.ac: Reflect changes above.
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-0116-0/+803
* Added macro support to ITRON API. This is known to compile. * Makefile.am: Added macros directory. * configure.in: Removed error check for enabling macros. * macros/.cvsignore, macros/Makefile.am, macros/rtems/.cvsignore, macros/rtems/Makefile.am, macros/rtems/itron/.cvsignore, macros/rtems/itron/Makefile.am, macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl, macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl, macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl, macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl, macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl, macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl: New files.
