* | New header guards. | Ralf Corsepius | 2005-01-28 | 30 | -60/+60 |
* | Add doxygen preamble. | Ralf Corsepius | 2004-11-21 | 30 | -0/+120 |
* | Remove unnecessary white spaces. | Ralf Corsepius | 2004-04-15 | 29 | -62/+35 |
* | 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-23 | 10 | -37/+37 |
| | | | | | | | | | | | | | | | | | | * itron/include/itronsys/mbox.h, itron/include/itronsys/types.h, itron/include/rtems/itron/eventflags.h, itron/include/rtems/itron/fmempool.h, itron/include/rtems/itron/mbox.h, itron/include/rtems/itron/msgbuffer.h, itron/include/rtems/itron/port.h, itron/include/rtems/itron/semaphore.h, itron/include/rtems/itron/task.h, itron/include/rtems/itron/vmempool.h, itron/inline/rtems/itron/semaphore.inl, itron/macros/rtems/itron/semaphore.inl, itron/src/eventflags.c, itron/src/fmempool.c, itron/src/itronsem.c, itron/src/mbox.c, itron/src/msgbuffer.c, itron/src/port.c, itron/src/snd_mbx.c, itron/src/task.c, itron/src/trcv_mbx.c, itron/src/vmempool.c: Convert to using c99 fixed size types. | ||||
* | Unused. | Ralf Corsepius | 2004-03-08 | 4 | -8/+0 |
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 30 | -30/+30 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/itron.h, include/itronsys/eventflags.h, include/itronsys/fmempool.h, include/itronsys/intr.h, include/itronsys/mbox.h, include/itronsys/msgbuffer.h, include/itronsys/network.h, include/itronsys/port.h, include/itronsys/semaphore.h, include/itronsys/status.h, include/itronsys/sysmgmt.h, include/itronsys/task.h, include/itronsys/time.h, include/itronsys/types.h, include/itronsys/vmempool.h, include/rtems/itron/config.h, include/rtems/itron/eventflags.h, include/rtems/itron/fmempool.h, include/rtems/itron/intr.h, include/rtems/itron/itronapi.h, include/rtems/itron/mbox.h, include/rtems/itron/msgbuffer.h, include/rtems/itron/network.h, include/rtems/itron/object.h, include/rtems/itron/port.h, include/rtems/itron/semaphore.h, include/rtems/itron/sysmgmt.h, include/rtems/itron/task.h, include/rtems/itron/time.h, include/rtems/itron/vmempool.h, inline/rtems/itron/eventflags.inl, inline/rtems/itron/fmempool.inl, inline/rtems/itron/intr.inl, inline/rtems/itron/mbox.inl, inline/rtems/itron/msgbuffer.inl, inline/rtems/itron/network.inl, inline/rtems/itron/port.inl, inline/rtems/itron/semaphore.inl, inline/rtems/itron/sysmgmt.inl, inline/rtems/itron/task.inl, inline/rtems/itron/time.inl, inline/rtems/itron/vmempool.inl, macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl, macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl, macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl, macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl, macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl, macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl, src/can_wup.c, src/chg_pri.c, src/cre_mbf.c, src/cre_mbx.c, src/cre_sem.c, src/cre_tsk.c, src/del_mbf.c, src/del_mbx.c, src/del_sem.c, src/del_tsk.c, src/dis_dsp.c, src/ena_dsp.c, src/eventflags.c, src/exd_tsk.c, src/ext_tsk.c, src/fmempool.c, src/frsm_tsk.c, src/get_tid.c, src/itronintr.c, src/itronsem.c, src/itrontime.c, src/mbox.c, src/mboxtranslatereturncode.c, src/msgbuffer.c, src/msgbuffertranslatereturncode.c, src/network.c, src/port.c, src/prcv_mbf.c, src/prcv_mbx.c, src/preq_sem.c, src/psnd_mbf.c, src/rcv_mbf.c, src/rcv_mbx.c, src/ref_mbf.c, src/ref_mbx.c, src/ref_sem.c, src/ref_tsk.c, src/rel_wai.c, src/rot_rdq.c, src/rsm_tsk.c, src/sig_sem.c, src/slp_tsk.c, src/snd_mbf.c, src/snd_mbx.c, src/sta_tsk.c, src/sus_tsk.c, src/sysmgmt.c, src/task.c, src/ter_tsk.c, src/trcv_mbf.c, src/trcv_mbx.c, src/tslp_tsk.c, src/tsnd_mbf.c, src/twai_sem.c, src/vmempool.c, src/wai_sem.c, src/wup_tsk.c: URL for license changed. | ||||
* | 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-09 | 1 | -55/+0 |
| | | | | | | | | | * include/Makefile.am: Remove. * inline/Makefile.am: Remove. * macros/Makefile.am: Remove. * src/Makefile.am: Remove. * Makefile.am: Merge-in removed Makefile.ams. * configure.ac: Reflect changes above. | ||||
* | 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-17 | 1 | -1/+1 |
| | | | | | | | | | * include/Makefile.am: Include $(top_srcdir)/../automake/*.am. * Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * inline/Makefile.am: Include $(top_srcdir)/../automake/*.am. * macros/Makefile.am: Include $(top_srcdir)/../automake/*.am. * src/Makefile.am: Include $(top_srcdir)/../automake/*.am. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -1/+0 |
| | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-11-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-11-07 | 1 | -1/+1 |
| | | | | | | Discovered while fixing PR36 reported by Todor.Todorov@barco.com. * include/rtems/itron/object.h: Corrected _ITRON_Objects_Get() to use _Objects_Get_by_index(). | ||||
* | 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-16 | 1 | -8/+42 |
| | | | | | | | | | | | | | | * include/itronsys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/rtems/itron/Makefile.am: Remove. * inline/rtems/Makefile.am: Remove. * inline/rtems/itron/Makefile.am: Remove. * macros/rtems/Makefile.am: Remove. * macros/rtems/itron/Makefile.am: Remove. * include/Makefile.am: handle subdirs. * inline/Makefile.am: handle subdirs. * macros/Makefile.am: handle subdirs. * configure.ac: Reflect changes above. | ||||
* | 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-09-27 | 1 | -1/+1 |
| | | | | | | | | * include/itronsys/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * inline/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='. * macros/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='. | ||||
* | 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-02-05 | 1 | -4/+2 |
| | | | | | | | * include/Makefile.am, include/itronsys/Makefile.am, include/rtems/itron/Makefile.am, inline/rtems/itron/Makefile.am, macros/rtems/itron/Makefile.am: Apply include_*HEADERS instead of H_FILES. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -6/+3 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 4 | -0/+8 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-11-22 | 1 | -6/+6 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | .. a major configuration cleanup ... major enhancement of automake support. ... and it contains a *major* breakthough: Automake support for libchip and libmisc *LEAF* directories. To implement this I have used several nasty tricks * The basical trick is to wrap an old Makefile.in's contents into a Makefile.am and still continue to use (i.e include) the old *.cfg files. * Replaced each INSTALL_IF_CHANGE and INSTALL_VARIANT with make dependencies * Add a gnu-make ifdef AUTOMAKE to main.cfg to avoid conflicts between automake and RTEMS make rules * Replaced each install:: and preinstall:: rule with make dependencies * Replaced SUB_DIRS with SUBDIRS in all Makefile.ins (Automake convention) * Removed each manually added autoconf substitution which automake performs automatically. This is not yet full automake support, because using the temporary installation directory, preinstallation in general and building variants are in contradiction to automake's basic working principles ... ... the new Makefile.ams work still somewhat clumsy ... nevertheless they work (quite well). WARNING: At first glance this patch is small, but * it affects the whole configuration system. * it opens the road to introducing automake to all Makefile.ins currently not being under automake control. JOEL> Does this remove or add any files? Both, all Makefile.ins below libchip and libmisc get replaced with Makefile.ams. | ||||
* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 30 | -2/+88 |
* | Updated Mailbox Manager submitted and split into multiple files. | Joel Sherrill | 1999-11-17 | 2 | -12/+28 |
* | Comment fixed when adding prototype for | Joel Sherrill | 1999-11-16 | 1 | -2/+11 |
| | | | | _ITRON_Message_buffer_Translate_core_message_buffer_return_code. | ||||
* | Returned third parameter for a NULL name to the objects open call. | Jennifer Averett | 1999-11-15 | 1 | -1/+1 |
* | Removed unnecessary 3rd parameter. | Joel Sherrill | 1999-11-12 | 1 | -1/+1 |
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-10 | 3 | -3/+12 |
| | | | | Working Group. Included are tests. | ||||
* | Commented out single letter type names since they conflict with | Joel Sherrill | 1999-11-09 | 1 | -0/+6 |
| | | | | numerous other uses of the same variable. | ||||
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 33 | -0/+3049 |
for RTEMS. |
