* include/Makefile.am, include/itronsys/Makefile.am,
include/rtems/itron/Makefile.am, inline/rtems/itron/Makefile.am,
macros/rtems/itron/Makefile.am:
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
_ITRON_Message_buffer_Translate_core_message_buffer_return_code.
numerous other uses of the same variable.
for RTEMS.
