path: root/cpukit/itron/include (follow)
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-134-0/+8
| | | | adds .cvsignore.
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-6/+6
* + Updated copyright information.Jennifer Averett1999-11-1730-2/+88
* Updated Mailbox Manager submitted and split into multiple files.Joel Sherrill1999-11-172-12/+28
* Comment fixed when adding prototype forJoel Sherrill1999-11-161-2/+11
| | | | _ITRON_Message_buffer_Translate_core_message_buffer_return_code.
* Returned third parameter for a NULL name to the objects open call.Jennifer Averett1999-11-151-1/+1
* Removed unnecessary 3rd parameter.Joel Sherrill1999-11-121-1/+1
* Committed modifications from ITRON Task and Task Dependendent SynchronizationJoel Sherrill1999-11-103-3/+12
| | | | Working Group. Included are tests.
* Commented out single letter type names since they conflict withJoel Sherrill1999-11-091-0/+6
| | | | numerous other uses of the same variable.
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-0933-0/+3049
for RTEMS.
