path: root/cpukit/itron/include/itronsys/types.h (unfollow)
2010-06-17Remove (Abandoned).Ralf Corsepius1-126/+0
2009-01-052009-01-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-12/+12
* itron/include/itronsys/types.h: ITRON types should follow native integer size.
2008-12-192008-12-19 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-1/+3
* itron/include/itronsys/types.h: Derive ITRON ID type from Objects_Id to avoid sizing mismatches.
2008-09-07Eliminate "boolean".Ralf Corsepius1-1/+1
2008-08-01Add missing prototype.Ralf Corsepius1-1/+1
2005-01-28New header guards.Ralf Corsepius1-2/+2
2004-11-21Add doxygen preamble.Ralf Corsepius1-0/+4
2004-04-15Remove unnecessary white spaces.Ralf Corsepius1-5/+4
2004-03-232004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-20/+20
* itron/include/itronsys/mbox.h, itron/include/itronsys/types.h, itron/include/rtems/itron/eventflags.h, itron/include/rtems/itron/fmempool.h, itron/include/rtems/itron/mbox.h, itron/include/rtems/itron/msgbuffer.h, itron/include/rtems/itron/port.h, itron/include/rtems/itron/semaphore.h, itron/include/rtems/itron/task.h, itron/include/rtems/itron/vmempool.h, itron/inline/rtems/itron/semaphore.inl, itron/macros/rtems/itron/semaphore.inl, itron/src/eventflags.c, itron/src/fmempool.c, itron/src/itronsem.c, itron/src/mbox.c, itron/src/msgbuffer.c, itron/src/port.c, itron/src/snd_mbx.c, itron/src/task.c, itron/src/trcv_mbx.c, itron/src/vmempool.c: Convert to using c99 fixed size types.
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* include/itron.h, include/itronsys/eventflags.h, include/itronsys/fmempool.h, include/itronsys/intr.h, include/itronsys/mbox.h, include/itronsys/msgbuffer.h, include/itronsys/network.h, include/itronsys/port.h, include/itronsys/semaphore.h, include/itronsys/status.h, include/itronsys/sysmgmt.h, include/itronsys/task.h, include/itronsys/time.h, include/itronsys/types.h, include/itronsys/vmempool.h, include/rtems/itron/config.h, include/rtems/itron/eventflags.h, include/rtems/itron/fmempool.h, include/rtems/itron/intr.h, include/rtems/itron/itronapi.h, include/rtems/itron/mbox.h, include/rtems/itron/msgbuffer.h, include/rtems/itron/network.h, include/rtems/itron/object.h, include/rtems/itron/port.h, include/rtems/itron/semaphore.h, include/rtems/itron/sysmgmt.h, include/rtems/itron/task.h, include/rtems/itron/time.h, include/rtems/itron/vmempool.h, inline/rtems/itron/eventflags.inl, inline/rtems/itron/fmempool.inl, inline/rtems/itron/intr.inl, inline/rtems/itron/mbox.inl, inline/rtems/itron/msgbuffer.inl, inline/rtems/itron/network.inl, inline/rtems/itron/port.inl, inline/rtems/itron/semaphore.inl, inline/rtems/itron/sysmgmt.inl, inline/rtems/itron/task.inl, inline/rtems/itron/time.inl, inline/rtems/itron/vmempool.inl, macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl, macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl, macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl, macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl, macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl, macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl, src/can_wup.c, src/chg_pri.c, src/cre_mbf.c, src/cre_mbx.c, src/cre_sem.c, src/cre_tsk.c, src/del_mbf.c, src/del_mbx.c, src/del_sem.c, src/del_tsk.c, src/dis_dsp.c, src/ena_dsp.c, src/eventflags.c, src/exd_tsk.c, src/ext_tsk.c, src/fmempool.c, src/frsm_tsk.c, src/get_tid.c, src/itronintr.c, src/itronsem.c, src/itrontime.c, src/mbox.c, src/mboxtranslatereturncode.c, src/msgbuffer.c, src/msgbuffertranslatereturncode.c, src/network.c, src/port.c, src/prcv_mbf.c, src/prcv_mbx.c, src/preq_sem.c, src/psnd_mbf.c, src/rcv_mbf.c, src/rcv_mbx.c, src/ref_mbf.c, src/ref_mbx.c, src/ref_sem.c, src/ref_tsk.c, src/rel_wai.c, src/rot_rdq.c, src/rsm_tsk.c, src/sig_sem.c, src/slp_tsk.c, src/snd_mbf.c, src/snd_mbx.c, src/sta_tsk.c, src/sus_tsk.c, src/sysmgmt.c, src/task.c, src/ter_tsk.c, src/trcv_mbf.c, src/trcv_mbx.c, src/tslp_tsk.c, src/tsnd_mbf.c, src/twai_sem.c, src/vmempool.c, src/wai_sem.c, src/wup_tsk.c: URL for license changed.
1999-11-17+ Updated copyright information.Jennifer Averett1-0/+3
1999-11-10Committed modifications from ITRON Task and Task Dependendent SynchronizationJoel Sherrill1-2/+0
1999-11-09Commented out single letter type names since they conflict withJoel Sherrill1-0/+6
numerous other uses of the same variable.
1999-11-09This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1-0/+114
for RTEMS.
