* include/itronsys/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/Makefile.am: Revamp INCLUDES handling to make automake-1.5
* src/snd_mbx.c, src/tsnd_mbf.c: Unblocking message queue operations
should NOT use _Thread_Executing for return status since it is
permissible to invoke message send operations from an ISR. This was
reported by Suvrat Gupta <suvrat@utstar.com>.
* configure.in: Add [-ansi -fasm] to RTEMS_PROG_CC_FOR_TARGET.
* include/Makefile.am, include/itronsys/Makefile.am,
include/rtems/itron/Makefile.am, inline/rtems/itron/Makefile.am,
* Added macro support to ITRON API. This is known to compile.
* Makefile.am: Added macros directory.
* configure.in: Removed error check for enabling macros.
* macros/.cvsignore, macros/Makefile.am,
macros/rtems/.cvsignore, macros/rtems/Makefile.am,
macros/rtems/itron/.cvsignore, macros/rtems/itron/Makefile.am,
macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl,
macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl,
macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl,
macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl,
macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl,
macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl: New files.
* src/Makefile.am: Include compile.am.
