path: root/cpukit/itron/ChangeLog (follow)
* 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-191-0/+4
| | | | * src/Makefile.am: Add multilib support.
* 2001-11-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-071-0/+6
| | | | | | Discovered while fixing PR36 reported by Todor.Todorov@barco.com. * include/rtems/itron/object.h: Corrected _ITRON_Objects_Get() to use _Objects_Get_by_index().
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-161-0/+14
| | | | | | | | | | | | | | * include/itronsys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/rtems/itron/Makefile.am: Remove. * inline/rtems/Makefile.am: Remove. * inline/rtems/itron/Makefile.am: Remove. * macros/rtems/Makefile.am: Remove. * macros/rtems/itron/Makefile.am: Remove. * include/Makefile.am: handle subdirs. * inline/Makefile.am: handle subdirs. * macros/Makefile.am: handle subdirs. * configure.ac: Reflect changes above.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-111-0/+6
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-271-0/+8
| | | | | | | | * include/itronsys/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * inline/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='. * macros/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-241-0/+5
| | | | * src/Makefile.am: Revamp INCLUDES handling to make automake-1.5
* 2001-08-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-091-0/+7
| | | | | | | * src/snd_mbx.c, src/tsnd_mbf.c: Unblocking message queue operations should NOT use _Thread_Executing for return status since it is permissible to invoke message send operations from an ISR. This was reported by Suvrat Gupta <suvrat@utstar.com>.
* 2001-04-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-071-0/+4
| | | | * configure.in: Add [-ansi -fasm] to RTEMS_PROG_CC_FOR_TARGET.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-0/+7
| | | | | | | * include/Makefile.am, include/itronsys/Makefile.am, include/rtems/itron/Makefile.am, inline/rtems/itron/Makefile.am, macros/rtems/itron/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-241-0/+7
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-011-0/+15
| | | | | | | | | | | | | | | * Added macro support to ITRON API. This is known to compile. * Makefile.am: Added macros directory. * configure.in: Removed error check for enabling macros. * macros/.cvsignore, macros/Makefile.am, macros/rtems/.cvsignore, macros/rtems/Makefile.am, macros/rtems/itron/.cvsignore, macros/rtems/itron/Makefile.am, macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl, macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl, macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl, macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl, macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl, macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl: New files.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-0/+4
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+4
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-251-0/+5
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+4
| | | | * src/Makefile.am: Include compile.am.
