* include/itron.h, include/itronsys/eventflags.h,
include/itronsys/fmempool.h, include/itronsys/intr.h,
include/itronsys/mbox.h, include/itronsys/msgbuffer.h,
include/itronsys/network.h, include/itronsys/port.h,
include/itronsys/semaphore.h, include/itronsys/status.h,
include/itronsys/sysmgmt.h, include/itronsys/task.h,
include/itronsys/time.h, include/itronsys/types.h,
include/itronsys/vmempool.h, include/rtems/itron/config.h,
include/rtems/itron/eventflags.h, include/rtems/itron/fmempool.h,
include/rtems/itron/intr.h, include/rtems/itron/itronapi.h,
include/rtems/itron/mbox.h, include/rtems/itron/msgbuffer.h,
include/rtems/itron/network.h, include/rtems/itron/object.h,
include/rtems/itron/port.h, include/rtems/itron/semaphore.h,
include/rtems/itron/sysmgmt.h, include/rtems/itron/task.h,
include/rtems/itron/time.h, include/rtems/itron/vmempool.h,
inline/rtems/itron/eventflags.inl, inline/rtems/itron/fmempool.inl,
inline/rtems/itron/intr.inl, inline/rtems/itron/mbox.inl,
inline/rtems/itron/msgbuffer.inl, inline/rtems/itron/network.inl,
inline/rtems/itron/port.inl, inline/rtems/itron/semaphore.inl,
inline/rtems/itron/sysmgmt.inl, inline/rtems/itron/task.inl,
inline/rtems/itron/time.inl, inline/rtems/itron/vmempool.inl,
macros/rtems/itron/eventflags.inl, macros/rtems/itron/fmempool.inl,
macros/rtems/itron/intr.inl, macros/rtems/itron/mbox.inl,
macros/rtems/itron/msgbuffer.inl, macros/rtems/itron/network.inl,
macros/rtems/itron/port.inl, macros/rtems/itron/semaphore.inl,
macros/rtems/itron/sysmgmt.inl, macros/rtems/itron/task.inl,
macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl,
src/can_wup.c, src/chg_pri.c, src/cre_mbf.c, src/cre_mbx.c,
src/cre_sem.c, src/cre_tsk.c, src/del_mbf.c, src/del_mbx.c,
src/del_sem.c, src/del_tsk.c, src/dis_dsp.c, src/ena_dsp.c,
src/eventflags.c, src/exd_tsk.c, src/ext_tsk.c, src/fmempool.c,
src/frsm_tsk.c, src/get_tid.c, src/itronintr.c, src/itronsem.c,
src/itrontime.c, src/mbox.c, src/mboxtranslatereturncode.c,
src/msgbuffer.c, src/msgbuffertranslatereturncode.c, src/network.c,
src/port.c, src/prcv_mbf.c, src/prcv_mbx.c, src/preq_sem.c,
src/psnd_mbf.c, src/rcv_mbf.c, src/rcv_mbx.c, src/ref_mbf.c,
src/ref_mbx.c, src/ref_sem.c, src/ref_tsk.c, src/rel_wai.c,
src/rot_rdq.c, src/rsm_tsk.c, src/sig_sem.c, src/slp_tsk.c,
src/snd_mbf.c, src/snd_mbx.c, src/sta_tsk.c, src/sus_tsk.c,
src/sysmgmt.c, src/task.c, src/ter_tsk.c, src/trcv_mbf.c,
src/trcv_mbx.c, src/tslp_tsk.c, src/tsnd_mbf.c, src/twai_sem.c,
src/vmempool.c, src/wai_sem.c, src/wup_tsk.c: URL for license
changed.
* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am:
* src/config.h: New.
* Makefile.am: Don't create $ARCH as side-effect of compilation.
* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* configure.ac: Cosmetical fixes.
* configure.ac: Fix package name.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* src/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES.
* configure.ac: RTEMS_TOP(../..).
* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* src/cre_mbf.c, src/cre_sem.c, src/eventflags.c, src/fmempool.c,
src/itronsem.c, src/mbox.c, src/msgbuffer.c, src/port.c, src/task.c,
src/vmempool.c: Modified as part of above.
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
* configure.ac: Remove references to RTEMS_BSP.
* src/Makefile.am: Add libitron.a.
Use ../aclocal.
* inline/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* macros/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/task.c (_ITRON_Task_User_extensions): Add new fields to
be correct in respect to newly added fields for separate switch list.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/Makefile.am: Add multilib support.
Discovered while fixing PR36 reported by Todor.Todorov@barco.com.
* include/rtems/itron/object.h: Corrected _ITRON_Objects_Get()
to use _Objects_Get_by_index().
* include/itronsys/Makefile.am: Remove.
* include/rtems/itron/Makefile.am: Remove.
* inline/rtems/itron/Makefile.am: Remove.
* macros/rtems/itron/Makefile.am: Remove.
* include/Makefile.am: handle subdirs.
* inline/Makefile.am: handle subdirs.
* macros/Makefile.am: handle subdirs.
* configure.in: Remove.
* include/itronsys/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/itron/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/Makefile.am: Revamp INCLUDES handling to make automake-1.5
* src/snd_mbx.c, src/tsnd_mbf.c: Unblocking message queue operations
should NOT use _Thread_Executing for return status since it is
permissible to invoke message send operations from an ISR. This was
reported by Suvrat Gupta <suvrat@utstar.com>.
* configure.in: Add [-ansi -fasm] to RTEMS_PROG_CC_FOR_TARGET.
* include/Makefile.am, include/itronsys/Makefile.am,
include/rtems/itron/Makefile.am, inline/rtems/itron/Makefile.am,
* Added macro support to ITRON API. This is known to compile.
* Makefile.am: Added macros directory.
* configure.in: Removed error check for enabling macros.
* macros/.cvsignore, macros/Makefile.am,
macros/rtems/.cvsignore, macros/rtems/Makefile.am,
macros/rtems/itron/.cvsignore, macros/rtems/itron/Makefile.am,
macros/rtems/itron/time.inl, macros/rtems/itron/vmempool.inl: New files.
* src/Makefile.am: Include compile.am.
