Rename _Stack_Free_nothing() in _Objects_Free_nothing() to make it
reusable for the message queue buffers.
Update #4007.
Document changed error status.
Update #4401.
Document new error status.
These two functions are no longer used outside of _Once().
Flexible array members must not appear in the middle of a structure.
The __builtin_unreachable() cannot be used with current GCC versions to
tell the compiler that a function does not return to the caller, see:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151
Add a no return variant of _Thread_Dispatch_direct() to avoid generation
of dead code.
Update #3866.
This may reduce the code size a bit.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
This avoids having conditional statements to get the API-specific status
code.
code.
In case the processor set is not large enough to contain the processor
affinity set of the task return RTEMS_INVALID_SIZE instead of
RTEMS_INVALID_NUMBER. This is more in line with other directives since
the issue is related to the size of an object.
Close #4393.
code.
Close #4392.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
A timer may be also reinitiated by the timer server fire directives.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
This patch fixes issue #4338 by changing _TOD_Validate()
to only accept years till 2105. This requires another patch
to change the documentation of rtems_clock_set() and other
affected API functions (indicating the end date is 2105 not 2514).
I tried to support till year 2514 but it turned out that
this needs changing the Timer Manager too. That in turn
would mean to change _TOD_Seconds_since_epoch( void )
from 32 to 64 bit. Sebastian pointed out that a naive extension
leads to trouble with 32 bit processors. He deemed a safe
re-implementation too costly performance wise considering
that year 2106 is far away and current binaries using RTEMS
Classic API are unlikely to be in use by 2106.
The constant TOD_SECONDS_AT_2100_03_01_00_00 in
cpukit/rtems/src/clocktodtoseconds.c happens to be wrong by
1 hour. When setting the date 2100-Feb-28 23:59:59 and then
reading the date again you will find yourself in 2100-Feb-27.
Update #4338
Move RTEMS_Malloc_Sbrk_amount to the only implementation file which uses
it and make it private to hide implementation-details from an API
header.
Last use was removed by:
commit 54550e048d3a49435912797d2024f80671e93267
Author: Sebastian Huber <sebastian.huber@embedded-brains.de>
Date: Fri May 13 08:16:30 2016 +0200
posix: Rework pthread_join()
Rework pthread_join() to use _Thread_Join().
This reverts commit 8383572963e261ea384cddfa43cd9606e7c23cdd.
Update #3850
Update #3850
The directive returns RTEMS_UNSATISFIED if the semaphore's count already
had the maximum value of UINT32_MAX.
Replace Objects_Name_or_id_lookup_errors with new Status_Control codes.
Get rid of the _Status_Object_name_errors_to_status lookup table.
The value of STATUS_CLASSIC_INTERNAL_ERROR must be equal to
RTEMS_INTERNAL_ERROR. Add static assertions to ensure that the status
codes match.
Do not adjust the stack area begin address since this may confuse the
stack allocator and result in failed stack frees.
Account for the alignment overhead in the stack space size estimate.
Check that the stack size is in the expected interval.
Adds a peek function that allows (for example) a file system to suggest
the next blocks that should be used for read ahead. This can increase
the read speed of fragmented files.
Update #3689
Rejecting initially locked MrsP semaphores was due to a limitiation of
the early limitiation of the MrsP protocol. This limitation no longer
exists.
MrsP semaphores are a generalization of the priority ceiling semaphores
for SMP configurations. Priority ceiling semaphores are required to use
the priority task wait queue discipline. Require this discipline also
for MrsP semaphores.
Close #4347.
Move the CPU time budget to the thread configuration. This simplifies
_Thread_Initialize().
According to commentary on GCC bug
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99143, the alignment
behavior of linker sections on which RTEMS has relied was never
guaranteed to be consistent across platforms and any alignment
requirements for linker sections needs to be enforced explicitly.
This adds those explicit alignment requirements.
Closes #4255.
Make sure that a user-provided stack size is the minimum size allocated
for the stack.
Make sure we meet the stack alignment requirement also for CPU ports
with CPU_STACK_ALIGNMENT > CPU_HEAP_ALIGNMENT.
Ensure that CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE meets the task
storage alignment requirement.
Make sure we meet the stack alignment requirement for user-provided
thread storage areas.
Check for an integer overflow. Add a validation test for task create
errors.
Close the thread object if a thread create extension fails. Also call
the delete extension to avoid resource leaks in early extensions if a
late extension fails.
Close #4270.
Update #4267.
Update #4267.
