path: root/cpukit/include (follow)
* 2009-10-08 Chris Johns <chrisj@rtems.org>Chris Johns2009-10-081-0/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am: Added statvfs.h. * libcsupport/Makefile.am: Add statvfs.c. * libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c: New. * libcsupport/include/rtems/libio.h: Add a file system handler for the statvfs call. * libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the statvfs handler to NULL. * include/rtems/fs.h: Add a second node access field for the RFS file system to hold a directory offset while the existing field holds the inode number. This save a rescan of the directory when working with directories. * libblock/include/rtems/bdbuf.h: Added references and user fields to the buffer descriptor. * libblock/src/bdbuf.c: Added dynamic buffer support for different block sizes. Fixed a number of bugs. * libblock/src/blkdev.c: Release the disk device on an error. * libblock/src/diskdevs.c: Set the block size to the media block size during initialisation of the disk device. * libblock/src/flashdisk.c, libblock/src/nvdisk.c, libblock/src/ramdisk.c: Updated the drivers to handle variable block sizes. * libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any buffers when an error occurs. The FAT buffer layer hangs onto a single buffer while mounted. This should be fixed. * sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain, rtems_chain_is_node_off_chain, and rtems_chain_previous. * score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain, and _Chain_Is_node_off_chain. * libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c, libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h: New shell commands. * libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and mknod commands. * libmisc/shell/hexdump-display.c: Fixed the reopen bug which showed up as a free with a bad pointer. * libmisc/shell/main_mount.c: List the user adding file system when listing the available file systems to mount. * libmisc/shell/utils-cp.c: Remove the fixed static copy buffer and use a large dynamic buffer. * score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c, score/src/objectallocate.c, score/src/objectfree.c: Remove warnings.
* Make pci_[read|write]_config* static inline, again.Ralf Corsepius2009-10-011-6/+6
* 2009-10-01 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-011-1/+1
| | | | * include/rtems/pci.h: Add another missing prototype.
* 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-301-1/+1
| | | | * include/rtems/pci.h: Add missing prototype.
* 2009-09-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-09-281-6/+6
| | | | * include/rtems/pci.h: Revert extern inline patch.
* 2009-09-25 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-09-251-6/+6
| | | | * include/rtems/pci.h: Change extern inline to static inline.
* 2009-08-05 Sebastian Huber <sebastian.huber@embedded-brains.de>Joel Sherrill2009-08-051-72/+131
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/include/rtems/libio_.h, libcsupport/src/fs_null_handlers.c: Null handlers are now const. * libi2c/libi2c.c, libi2c/libi2c.h: Documentation. Do not create semaphores on the fly. * cpukit/libblock/src/bdpart.c: Fixed format specifier. * cpukit/libblock/include/rtems/bdbuf.h, rtems/include/rtems.h, rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/barriermp.h, rtems/include/rtems/rtems/cache.h, rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/event.h, rtems/include/rtems/rtems/eventmp.h, rtems/include/rtems/rtems/eventset.h, rtems/include/rtems/rtems/intr.h, rtems/include/rtems/rtems/message.h, rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/mp.h, rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/partmp.h, rtems/include/rtems/rtems/ratemon.h, rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/regionmp.h, rtems/include/rtems/rtems/rtemsapi.h, rtems/include/rtems/rtems/sem.h, rtems/include/rtems/rtems/semmp.h, rtems/include/rtems/rtems/signal.h, rtems/include/rtems/rtems/signalmp.h, rtems/include/rtems/rtems/status.h, rtems/include/rtems/rtems/support.h, rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h, rtems/inline/rtems/rtems/support.inl: Documentation. * include/rtems/irq-extension.h: Documentation. Added API for interrupt servers.
* 2009-06-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-06-161-0/+1
| | | | | * include/rtems/bspIo.h, libcsupport/Makefile.am: Add putk(). * libcsupport/src/putk.c: New file.
* 2009-05-15 Sebastian Huber <sebastian.huber@embedded-brains.de>Joel Sherrill2009-05-151-2/+2
| | | | | | | | | | | | * Doxygen.in: Fixed project name. Added project number. Enabled auto brief. Disabled include graphs. * include/rtems/irq-extension.h, libblock/include/rtems/bdpart.h, libblock/include/rtems/bdbuf.h, libblock/include/rtems/bdpart.h, libblock/include/rtems/blkdev.h, libblock/include/rtems/diskdevs.h, libblock/include/rtems/ramdisk.h, libblock/src/bdbuf.c, libblock/src/blkdev.c, libblock/src/diskdevs.c, libblock/src/ramdisk.c: Documentation. * libblock/src/bdpart.c: Documentation. Fixed NULL pointer access.
* Added functions to translate integers to/from byte streams.Thomas Doerfler2009-05-051-0/+132
* New.Ralf Corsepius2009-02-201-0/+2
* 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-02-192-13/+10
| | | | | * include/rtems/irq-extension.h, include/rtems/irq.h: Spelling errors and spacing.
* Remove (Abandoned).Ralf Corsepius2008-12-171-24/+0
* libnetworking/rtems/rtems_glue.c: Copy nothing if ↵Thomas Doerfler2008-10-101-85/+237
| | | | | | rtems_bsdnet_parse_driver_name() if namep is NULL. include/rtems/status-checks.h: Added prefix "RTEMS" for all macros. Doxygen style comments. Cleanup.
* 2008-09-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-221-1/+12
| | | | | | * include/rtems/bspIo.h, libcsupport/Makefile.am: Add genchark() for polled debug input from the same device as printk(). * libcsupport/src/getchark.c: New file.
* 2008-08-20 Sebastian Huber <sebastian.huber@embedded-brains.de>Joel Sherrill2008-08-201-2/+2
| | | | * include/rtems/status-checks.h: Fixed integer conversion warning.
* New function rtems_interrupt_handler_iterate()Thomas Doerfler2008-07-241-10/+46
| | | | for system information and diagnostics
* added BSP to m68kThomas Doerfler2008-07-111-3/+9
| | | | adapted PPC exception code
* 2008-07-10 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-07-101-132/+143
| | | | * include/rtems/status-checks.h: Fix style.
* added irq-extension.h declarationsThomas Doerfler2008-07-101-0/+171
* Macros for status code and return value checks.Thomas Doerfler2008-07-101-0/+176
* Added const qualifier to various pointers and data tables toThomas Doerfler2008-05-271-4/+4
| | | | | | reduce size of data area. IMFS: Fixed creation of symbolic links to avoid a compiler warning. DOSFS: Use LibBlock instead of read() to read the boot record.
* 2007-09-06 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-09-061-2/+19
| | | | | | | | | | | | | | | | * libcsupport/Makefile.am, libcsupport/src/printk.c: * libcsupport/src/printk_plugin.c: New file. include/rtems/bspIo.h, libmisc/cpuuse/cpuusagereport.c, libmisc/cpuuse/cpuuse.h, libmisc/stackchk/check.c, libmisc/stackchk/stackchk.h: rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemonreportstatistics.c: Added capability to specify your own "printf" routine to various reporting functions. This added an XXX_with_plugin as the underlying implementation for + rtems_rate_monotonic_report_statistics + rtems_stack_checker_report_usage + rtems_cpu_usage_report As demonstration, the http netdemo can now print out stack and cpu usage reports.
* 2007-07-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-07-262-0/+16
| | | | | | * include/rtems/bspIo.h, include/rtems/pci.h: Add extern "C" guards. Reported by Robert S. Grimes <rsg@alum.mit.edu>.
* Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>.Ralf Corsepius2007-05-101-1/+1
* New.Ralf Corsepius2007-05-101-0/+180
* 2007-05-10 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-05-101-0/+602
| | | | | * include/rtems/bsd/sys/queue.h: New (Copied from libnetworking/sys/queue.h).
* 2007-05-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-05-091-0/+92
| | | | | * include/rtems/endian.h: New (Copied from libnetworking/machine/endian.h).
* adapted BSP "motorola_powerpc" to support MVME24xxThomas Doerfler2007-04-091-0/+1
* 2007-03-31 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-03-311-6/+6
| | | | * include/rtems/pci.h: Further stdint.h fixed-size types.
* 2007-03-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-03-301-6/+8
| | | | * include/rtems/pci.h: Use stdint.h fixed size-types.
* Abandon DEPRECATED_TYPES.Ralf Corsepius2006-12-131-16/+0
* 2005-11-10 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-101-0/+2
| | | | * include/rtems/stdint.h: Disable RTEMS proprietary fixed-size types.
* 2005-10-31 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-311-4/+3
| | | | | PR 840/rtems: * include/rtems/irq.h: Fix several typos.
* 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-271-0/+3
| | | | * include/rtems/concat.h: Add EXPAND0, CONCAT0.
* 2005-05-17 Jennifer Averett <jennifer.averett@oarcorp.com>Jennifer Averett2005-05-171-0/+218
| | | | | * Makefile.am, preinstall.am: Added a common irq.h * include/rtems/irq.h: New file.
* 2005-05-04 Jennifer Averett <jennifer.averett@oarcorp.com>Jennifer Averett2005-05-041-1/+1
| | | | * include/rtems/pci.h: Name change to support common PCI interface
* 2005-03-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-03-141-0/+16
| | | | | * include/rtems/pci.h: Continue PCI API unification. All use pci_find_device().
* 2005-03-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-03-041-1066/+1119
| | | | | * include/rtems/pci.h: Clean up and reformatting. Make PCI initialize function part of the unified PCI API.
* 2005-02-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-02-171-4/+7
| | | | | * include/rtems/pci.h: Merge differences from libbsp/powerpc/shared/pci/pci.h.
* 2005-02-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-071-0/+53
| | | | * include/rtems/tar.h: New.
* New header guards.Ralf Corsepius2005-01-286-13/+13
* 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-281-0/+2
| | | | | * include/rtems/userenv.h: Set up LOGIN_NAME_MAX iff not having been defined before.
* 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-241-0/+14
| | | | | * include/rtems/stdint.h: Add signed8, signed16, signed32, unsigned8, unsigned16, unsigned32.
* 2004-11-10 Joel Sherrill <joel@oarcorp.com>Joel Sherrill2004-11-101-7/+7
| | | | | | | * include/rtems/pci.h: BSPs use the name BSP_pci_configuration not pci. Also need to address that this largely duplicates libbsp/powerpc/pci/pci.h but that file is not used when both are included due to the same double inclusion protection.
* 2004-11-05 Ralf Corsepius <ralf_corsepiu@rtems.org>Ralf Corsepius2004-11-051-38/+8
| | | | | | | * configure.ac: Remove RTEMS_USES_INTTYPES_H. Require inttypes.h. * include/rtems/stdint.h: Remove "wild guesses", require inttypes.h. * libcsupport/include/inttypes.h: Cleanup. * libcsupport/include/stdint.h: Cleanup.
* 2004-04-13 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-131-11/+30
| | | | | | | | | | | | * configure.ac: Rework stdint.h/inttypes.h support. Add RTEMS_USES_STDINT_H. Add RTEMS_USES_INTTYPES_H. Remove NEED_STDINT_H. Remove NEED_INTTYPES_H. Remove termios-flag detection. * libcsupport/Makefile.am: Install include/stdint.h and include/inttypes.h for NEWLIB only. * libcsupport/include/stdint.h: Rework; Now newlib specific. * libcsupport/src/termios.c: Make newlib specific. * include/rtems/stdint.h: Rework; Now wrapper to <stdint.h>.
* 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-291-0/+19
| | | | | | | | | | | | PR 561/rtems * include/rtems/concat.h: New. * Makefile.am: Add include/rtems/concat.h. PR/589 rtems * Makefile.am: Add include/rtems/pci.h. * Makefile.am: Include automake/compile.am. * configure.ac: RTEMS_TOP([..],[]).
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-231-0/+1153
| | | | | PR/589 rtems * include/rtems/pci.h: New (Moved from c/src/libchip/network/pci.h).
* Unused.Ralf Corsepius2004-03-081-2/+0
