- Report version, cpu, bsp, tools and options.
Updated this file with the newer version in NetBSD.
Updates #4682
Place the object control blocks in dedicated sections to allow a linker garbage
collection.
Update #4678.
The rtems_task_delete() directive is basically just a combined pthread_cancel()
and pthread_join(). In addition, it removes the PTHREAD_DETACHED state. The
exit value returned by pthread_join() of threads cancelled by
rtems_task_delete() should reflect this by getting a PTHREAD_CANCELED value
instead of NULL which could be a normal exit value.
Close #4680.
Threads may join the thread termination of another thread using the
pthread_join() or rtems_task_delete() directives. The thread cancel operation
used a special case priority boosting mechanism implemented by
_Thread_Raise_real_priority(). The problem was that this approach
* is not transitive,
* does not account for priority adjustments of the calling task
while waiting for the join,
* does not support clustered scheduling, and
* does not detect deadlocks.
All these problems are fixed by using a priority inheritance thread queue for
the join operation.
Close #4679.
The objects local table must be statically zero-initialized so that
_Objects_Get() and _Objects_Get_no_protection() return NULL if no object is
associated with the identifier.
Update #4678.
The uniprocessor schedulers had some special case logic for the
PRIORITY_PSEUDO_ISR priority. Tasks with a priority of PRIORITY_PSEUDO_ISR
were allowed to preempt a not preemptible task. If other higher priority task
are made ready while a PRIORITY_PSEUDO_ISR task preempts a not preemptible
task, then the other tasks run before the not preemptible task. This made the
RTEMS_NO_PREEMPT mode ineffective.
Remove the PRIORITY_PSEUDO_ISR special case logic. This simplifies the
uniprocessor schedulers. Move the uniprocessor-specific scheduler support to
the new header file <rtems/score/scheduleruniimpl.h>.
Close #2365.
In case the Newlib _REENT_THREAD_LOCAL configuration option is enabled, the
struct _reent is not defined (there is only a forward declaration in
<sys/reent.h>). Instead, the usual members of struct _reent are available as
dedicatd thread-local storage objects.
Update #4560.
Commit 21275b58a5a69c3c838082ffc8a7a3641f32ea9a ("score: Static
Objects_Information initialization") introduced an off-by-one error in the
maintenance of inactive objects.
Close #4677.
Dirty or zero also the part of the .noinit section used by RTEMS.
Close #4678.
Place the statically allocated object control blocks, local tables, and thread
queue heads into the dedicated .noinit intput sections. The output section is
not zero initialized. Placing these elements into the .noinit section reduces
the system initialization time by decreasing the .bss section size.
It may improve the cache efficiency since the mostly read local tables are
placed in a contiguous memory area.
Update #4678.
Check if given address/FIB exists locally.
Reviewed by: melifaro
Differential revision: https://reviews.freebsd.org/D32913
The modification to the hash are already naturally locked by
in_control_sx. Convert the hash lists to CK lists. Remove the
in_ifaddr_rmlock. Assert the network epoch where necessary.
Most cases when the hash lookup is done the epoch is already entered.
Cover a few cases, that need entering the epoch, which mostly is
initial configuration of tunnel interfaces and multicast addresses.
Differential revision: https://reviews.freebsd.org/D32584
Current logic always selects an IFA of the same family from the
outgoing interfaces. In IPv4 over IPv6 setup there can be just
single non-127.0.0.1 ifa, attached to the loopback interface.
Create a separate rt_getifa_family() to handle entire ifa selection
for the IPv4 over IPv6.
Differential Revision: https://reviews.freebsd.org/D31868
MFC after: 1 week
These functions were added in 2001 and are currently unused.
copyinfrom() looks to have never been used. copyinstrfrom() was used
for two weeks before the code was refactored to remove it's sole use.
Reviewed by: brooks, kib
Obtained from: CheriBSD
Sponsored by: DARPA
Differential Revision: https://reviews.freebsd.org/D24928
This function is only used in SMP configurations.
Update #4670.
Update #4667.
Update #4667.
Conditional expressions with inline functions are not optimized away if
optimization is disabled. Avoid such expressions to prevent dead
branches. It helps also during code review to immediately see if a loop
is used or not.
The original file cpukit/libfs/src/ftpfs/tftpDriver.c
is split into two:
tftpfs.c - This file contains the code from tftpDriver.c
related to file system operations such as mount(),
open(), read(), and so on.
tftpDriver.c - In the original file remains only the code related
to networking. This code implements the Trivial
File Transfer Protocol (TFTP).
Moreover, the code is extended to support
* RFC 2347 TFTP Option Extension
* RFC 2348 TFTP Blocksize Option
* RFC 7440 TFTP Windowsize Option
Update #4666.
Update #2349.
Update #2349.
Rename tc_getfrequency() to _Timecounter_Get_frequency().
Update #2349.
Update #2349.
Update #2349.
Use the copyright notice of the associated header file from FreeBSD if the
kernel space header file contains a substantial amount of imported code.
These files had no header, copyright, or license. Based on git history,
added appropriate copyrights and licenses.
This file had no header, copyright, or license. Based on git history,
added appropriate copyright and license.
These files had no header, copyright, or licenses. Based on git history,
These files had no file header, copyright, or license. Based on git
history, added appropriate copyright and license.
Close #4644.
In contrast to rtems_shell_main_loop(), this new function does not
perform all sorts of initialization based on environment settings. For
example, due to the use of isatty() in rtems_shell_main_loop() it is
impossible to run an interactive shell through a socket connection.
This was requested to be executed prior to relicensing to BSD-2.
Permission received from Krzysztof Miesowicz.
Updates #3053.
Permission received from Petr Benes
Updates #3053.
Updates #3053.
Updates #3053.
