Fix prototype.
Fix node size. Linfiles are dynamically turned into memfiles.
Update #3823.
Update #3818.
Integrate parts of this commit:
This commit brings in a new refactored TCP stack
called Rack. Rack includes the following features: - A different SACK
processing scheme (the old sack structures are not used). - RACK (Recent
acknowledgment) where counting dup-acks is no longer done instead time
is used to knwo when to retransmit. (see the I-D) - TLP (Tail Loss
Probe) where we will probe for tail-losses to attempt to try not to take
a retransmit time-out. (see the I-D) - Burst mitigation using TCPHTPS -
PRR (partial rate reduction) see the RFC.
Once built into your kernel, you can select this stack by either
socket option with the name of the stack is "rack" or by setting
the global sysctl so the default is rack.
Note that any connection that does not support SACK will be kicked
back to the "default" base FreeBSD stack (currently known as "default").
To build this into your kernel you will need to enable in your
kernel:
makeoptions WITH_EXTRA_TCP_STACKS=1
options TCPHPTS
Sponsored by: Netflix Inc.
Differential Revision: https://reviews.freebsd.org/D15525
Update #3806.
Use RTEMS_DEFINE_GLOBAL_SYMBOL_IN_SECTION() instead.
Close #3799.
Update #3799.
This allows more control over the initialization and finalization run.
Update #3199.
This ensures that lines are output atomically if they are produced by
different other contexts, e.g. interrupts, other processors, other
threads.
Update #3199.
This patch adds the ability for termios to send SIGINTR on receipt
of VINTR and SIGQUIT for VKILL and return -1/EINTR from read() on
a termios channel. Importantly, this patch does not alter the default
behavior or force POSIX signal code in just because termios is used.
The application must explicitly enable the POSIX behavior of generating
a signal upon receipt of these characters. This is discussed in the
POSIX standard:
https://pubs.opengroup.org/onlinepubs/9699919799/basedefs/V1_chap11.html
Closes #3800.
The use case for this function is the libbsd. In FreeBSD, the interrupt
setup and binding to a processor is done in two steps. Message
based interrupts like PCIe MSI and MSI-X interrupts can be implemented
through interrupt server entries. They are setup at the default
interrupt server and may optionally move to an interrupt server bound to
a specific processor.
Return the empty string instead of a NULL pointer if no version key is
available.
Update #3665.
Add system events for memory allocation/free.
Update #3665.
Add system events to identify the target system. Add system events to
transfer blocks of memory and register sets.
Update #3665.
The _Record_Initialize() function depends only initialized read-only
data. Call it as the first initialization step to allow tracing of the
complete system initialization.
Update #3665.
Update #3665.
This allows its use in crash dump procedures.
Update #3665.
Reduce the system dependencies to allow tracing of very low level
functions, for example the interrupt disable/enable.
Introduce general purpose RTEMS_RECORD_CALLER and RTEMS_RECORD_LINE
events.
Update #3665.
Update #3665.
This helps to get rid of the <rtems/rtems/tasks.h> dependency in
<rtems/record.h>.
Update #3665.
The .rtemsrwset section is used for the per-CPU data. This section has
loadable content. Place the ring buffers in the BSS section to avoid
large executable image sizes.
Not using the per-CPU data makes it possible to initialize the record
support earlier.
Update #3665.
This is necessary to get the thread names properly on 32-bit and 64-bit
targets.
Update #3665.
Signal the accumulated item overflow count with the time of the first
new item.
This is a minor optimization.
Do nothing after errors.
In case of a ring buffer overflow, the rtems_record_drain() will push
the complete ring buffer content to the client. While the items are
processed by the client, new items may overwrite some items being
processed. The overwritten items can be detected in the following
iteration once the next tail/head information is pushed to the client.
- Fix destorying the target and thread parts.
- Fix the ARM backend to support Cortex-A8 and ARM mode code.
- Use the DBGDSCR interrupt mask when single stepping.
- Use the DBGDSCR method of entry to debug mode to filter the
execptions.
- Add support for BSPs to control the ARM backend.
Add and use _Thread_Get_unmapped_real_priority().
- Replace the linear object file symbol search with a binary search.
- Sort the object file symbols after loading.
Closes #3748
All uses were replaced by per-processor jobs.
