Updated this file with the newer version in NetBSD.
Updates #4682
Update #2349.
Update #2349.
Rename tc_getfrequency() to _Timecounter_Get_frequency().
Update #2349.
Update #2349.
Update #2349.
Updates #3053.
Remove previous adjtime() implementation.
Update #2348.
It seems we need valid values or assumptions in the FreeBSD about
these values breaks some of the code.
Closes #4207
This makes the @file documentation independent of the actual file name.
Update #3707.
Update #3472.
Update #3472.
Update #3472.
Update #3472.
kevent(2) says.
This is a trivial comment-only fix. The man page for kevent(2) gives
the definition of struct kevent, including a comment on each
field. The actual definition in sys/event.h omitted the comments on
some fields. Add the comments in. Not only does this make the man page
and include file agree, but the comments are useful in and of
themselves.
Reviewed by: kib (D15778: commented that this should be a separate commit)
MFC after: 3 days
Sponsored by: Dell EMC
Reported by: bde@
MFC after: 1 day
The anonymous object initialization introduced in r335765 was
acceptable to clang, but not gcc 4.2.1. Fix it for both.
Reported by: jhibbits@
Pointy Hat: myself
MFC after: 1 week
X-MFC-with: r335765
PR43905 pointed out a problem with the EV_SET macro if the passed
struct kevent pointer were specified with an expression with side
effects (e.g., "kevp++"). This was fixed in rS110241, but by using a
local block that defined an internal variable (named "kevp") to get
the pointer value once. This worked, but could cause issues if an
existing variable named "kevp" is in scope. To avoid that issue,
jilles@ pointed out that "C99 compound literals and designated
initializers allow doing this cleanly using a macro". This change
incorporates that suggestion, essentially verbatim from jilles@
comment on PR43905, except retaining the old definition for pre-C99 or
non-STDC (e.g., C++) compilers.
PR: 43905
Submitted by: Jilles Tjoelker (jilles@)
Reported by: Lamont Granquist <lamont@scriptkiddie.org>
Reviewed by: jmg (no comments), jilles
MFC after: 1 week
Differential Revision: https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=43905
Mainly focus on files that use BSD 2-Clause license, however the tool I
was using misidentified many licenses so this was mostly a manual - error
prone - task.
The Software Package Data Exchange (SPDX) group provides a specification
to make it easier for automated tools to detect and summarize well known
opensource licenses. We are gradually adopting the specification, noting
that the tags are considered only advisory and do not, in any way,
superceed or replace the license texts.
- Add a new KTR_STRUCT_ARRAY ktrace record type which dumps an array of
structures.
The structure name in the record payload is preceded by a size_t
containing the size of the individual structures. Use this to
replace the previous code that dumped the kevent arrays dumped for
kevent(). kdump is now able to decode the kevent structures rather
than dumping their contents via a hexdump.
One change from before is that the 'changes' and 'events' arrays are
not marked with separate 'read' and 'write' annotations in kdump
output. Instead, the first array is the 'changes' array, and the
second array (only present if kevent doesn't fail with an error) is
the 'events' array. For kevent(), empty arrays are denoted by an
entry with an array containing zero entries rather than no record.
- Move kevent decoding tables from truss to libsysdecode.
This adds three new functions to decode members of struct kevent:
sysdecode_kevent_filter, sysdecode_kevent_flags, and
sysdecode_kevent_fflags.
kdump uses these helper functions to pretty-print kevent fields.
- Move structure definitions for freebsd11 and freebsd32 kevent
structures to <sys/event.h> so that they can be shared with userland.
The 32-bit structures are only exposed if _WANT_KEVENT32 is defined.
The freebsd11 structures are only exposed if _WANT_FREEBSD11_KEVENT is
defined. The 32-bit freebsd11 structure requires both.
- Decode freebsd11 kevent structures in truss for the compat11.kevent()
system call.
- Log 32-bit kevent structures via ktrace for 32-bit compat kevent()
system calls.
- While here, constify the 'void *data' argument to ktrstruct().
Reviewed by: kib (earlier version)
MFC after: 1 month
Differential Revision: https://reviews.freebsd.org/D12470
This change implements NOTE_ABSTIME flag for EVFILT_TIMER, which
specifies that the data field contains absolute time to fire the
event.
To make this useful, data member of the struct kevent must be extended
to 64bit. Using the opportunity, I also added ext members. This
changes struct kevent almost to Apple struct kevent64, except I did
not changed type of ident and udata, the later would cause serious API
incompatibilities.
The type of ident was kept uintptr_t since EVFILT_AIO returns a
pointer in this field, and e.g. CHERI is sensitive to the type
(discussed with brooks, jhb).
Unlike Apple kevent64, symbol versioning allows us to claim ABI
compatibility and still name the new syscall kevent(2). Compat shims
are provided for both host native and compat32.
Requested by: bapt
Reviewed by: bapt, brooks, ngie (previous version)
Sponsored by: The FreeBSD Foundation
Differential revision: https://reviews.freebsd.org/D11025
hist -> hint
MFC after: 3 days
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Required by new network stack.
These two header files were installed from libnetworking even
when networking was disabled. This patch moves them to a
non-networking location and updates uio.h to match the FreeBSD 8.x
source being used for the USB stack and TCP/IP stack upgrade.
- cpukit/include/memory.h
Move from cpukit/libnetworking/memory.h. No changes
- cpukit/include/sys/uio.h
Move from cpukit/libnetworking/sys/uio.h. Replace with FreeBSD 8.x version.
- cpukit/include/sys/_iovec.h
New. FreeBSD 8.x file supporting <sys/uio.h>.
- cpukit/Makefile.am
Reflect movement of <memory.h> and <sys/uio.h>.
- cpukit/preinstall.am
Regenerate
- cpukit/libnetworking/nfs/bootp_subr.c
Eliminate use of uio_procp field no longer in FreeBSD structure. This
field was set and never read so eliminating the set has no impact.
