path: root/cpukit/include/sha256.h (follow)
* Fix C++ includability of crypto headers with static array sizesAlan Somers2022-09-081-1/+2
| | | | | | | | | | | | | | | | | C99 allows array function parameters to use the static keyword for their sizes. This tells the compiler that the parameter will have at least the specified size, and calling code will fail to compile if that guarantee is not met. However, this syntax is not legal in C++. This commit reverts r300824, which worked around the problem for sys/sys/md5.h only, and introduces a new macro: min_size(). min_size(x) can be used in headers as a static array size, but will still compile in C++ mode. Reviewed by: cem, ed MFC after: 4 weeks Sponsored by: Spectra Logic Corp Differential Revision: https://reviews.freebsd.org/D8277
* crypto routines: Hint minimum buffer sizes to the compilerConrad Meyer2022-09-081-1/+1
| | | | | | | | | | | Use the C99 'static' keyword to hint to the compiler IVs and output digest sizes. The keyword informs the compiler of the minimum valid size for a given array. Obviously not every pointer can be validated (i.e., the compiler can produce false negative but not false positive reports). No functional change. No ABI change. Sponsored by: EMC / Isilon Storage Division
* Replace sys/crypto/sha2/sha2.c with lib/libmd/sha512c.cAllan Jude2022-09-081-3/+12
| | | | | | | | | | | | | | | | | | cperciva's libmd implementation is 5-30% faster The same was done for SHA256 previously in r263218 cperciva's implementation was lacking SHA-384 which I implemented, validated against OpenSSL and the NIST documentation Extend sbin/md5 to create sha384(1) Chase dependancies on sys/crypto/sha2/sha2.{c,h} and replace them with sha512{c.c,.h} Reviewed by: cperciva, des, delphij Approved by: secteam, bapt (mentor) MFC after: 2 weeks Sponsored by: ScaleEngine Inc. Differential Revision: https://reviews.freebsd.org/D3929
* Remove make preinstallChris Johns2018-01-251-0/+50
