Close #4863.
There was a cyclic dependency: For RTEMS_STATIC_ANALYSIS we needed
basedefs.h in assert.h. For RTEMS_UNREACHABLE() we needed _Assert() from
assert.h in basedefs.h.
Fix this by introducing _Debug_Unreachable() in basedefs.h.
Add RTEMS_FUNCTION_NAME to basedefs.h and use it in basedefs.h and
assert.h.
Close #4900.
This adds write buffer and bad block support required for JFFS2
operation on NAND devices. This also adds the minor modifications
necessary for RTEMS support in the Linux header stubs and in wbuf.c.
Memory and NOR backed applications should experience no difference in
operation since they do not expose the callbacks required for write
buffer support.
Update #3707.
The application configuration options are documented in
"cpukit/doxygen/appl-config.h". Since the application configuration
option defines are also present in multiple test program sources, the
"#OPTION" references cannot be mapped to a unique definition. Add an
anchor for each option and reference it to avoid the issues with the
multiple definitions.
Update #3994.
Closes #2828.
There are different cases for _ISR_lock_ISR_disable() and
_ISR_lock_ISR_enable() in the case RTEMS_SMP is defined or
RTEMS_PROFILING is defined, so remove the related code.
../../../cpukit/include/rtems/score/threaddispatch.h: In function '_Thread_Dispatch_disable':
../../../cpukit/include/rtems/score/threaddispatch.h:231:14: warning: 'lock_context' may be used uninitialized [-Wmaybe-uninitialized]
231 | cpu_self = _Thread_Dispatch_disable_critical( &lock_context );
../../../cpukit/include/rtems/score/threaddispatch.h:210:32: note: by argument 1 of type 'const ISR_lock_Context *' to '_Thread_Dispatch_disable_critical' declared here
210 | static inline Per_CPU_Control *_Thread_Dispatch_disable_critical(
../../../cpukit/include/rtems/score/threaddispatch.h:225:21: note: 'lock_context' declared here
225 | ISR_lock_Context lock_context;
Update #4662.
Several SMP message processing functions returned a value. This value
was always unused.
Close #4822.
Use standard wording in CPU usage reporting files.
Use standard wording in Clock Driver related files.
Update #3706.
Correctly calculate the array index and shift value in
_Processor_mask_To_uint32_t(). The bugs had no impact yet since this
function was always called with a zero value for the index in RTEMS.
This enables the tracing of interrupt entry/exit events through an
application configuration option. The interrupt processing can be
viewed with Trace Compass using rtems-record-lttng from the RTEMS Tools.
Update #4769.
Updates #4729
This patch changes the license to BSD-2 for all source files where the
copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research.
Some files also includes copyright right statements from OAR and/or
embedded Brains in addition to Gaisler.
Updates #3053.
This avoids a superfluous zero initialization of the task storage area. This
reduces the system initialization time.
- Optionally wait if there is no remote debugger connected and break
when the remote connects
Closes #4740
Ensure that the IDLE storage allocator did allocate a suffiently large area.
Update #3835.
Update #4524.
By default, allocate the IDLE task storage areas from the RTEMS Workspace.
This avoids having to estimate the thread-local storage size in the default
configuration.
Add the application configuration option CONFIGURE_IDLE_TASK_STORAGE_SIZE to
request a static allocation of the task storage area for IDLE tasks.
Update #3835.
Update #4524.
Add the INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED fatal error in case the
creation of an idle thread fails. This may happen due to a failing create
extension provided by the application.
Update #3835.
Place this member placed directly after the end of the common block so that
the structure offsets are as small as possible. This helps on instruction
set architectures with a very limited range for intermediate values. For
example, see the __aeabi_read_tp() implementation for ARM Thumb-1.
Update #3835.
Allow the IDLE stack allocator to change the stack size. This can be
used by applications with a very dynamic thread-local storage size to
adjust the thread storage area of the IDLE tasks dynamically.
Update #4524.
- Add support to get the parent address and size cells
- Provide support to get a reg prop address map
- Change getting a set of properties to uintptr_t
- Improve the debug mode of the ls command to print all props
Closes #4729
Update #3993.
Fix documentation.
Directly use "static inline" which is available in C99 and later. This brings
the RTEMS implementation closer to standard C.
Close #3935.
All CPU ports used the same _CPU_Counter_difference() implementation. Remove
this CPU port interface and mandate a monotonically increasing CPU counter.
Close #3456.
Directly include <rtems/score/cpuopts.h> in header files using CPU build
options.
Issue an error message if an SMP-specific scheduler is used and
RTEMS_SMP is disabled. This might be a more informative compared to
compiler or linker errors.
Two interface specification items moved.
Use RTEMS_ZERO_LENGTH_ARRAY for flexible array member.
Update #4662.
