- Report version, cpu, bsp, tools and options.
Place the object control blocks in dedicated sections to allow a linker garbage
collection.
Update #4678.
The rtems_task_delete() directive is basically just a combined pthread_cancel()
and pthread_join(). In addition, it removes the PTHREAD_DETACHED state. The
exit value returned by pthread_join() of threads cancelled by
rtems_task_delete() should reflect this by getting a PTHREAD_CANCELED value
instead of NULL which could be a normal exit value.
Close #4680.
Threads may join the thread termination of another thread using the
pthread_join() or rtems_task_delete() directives. The thread cancel operation
used a special case priority boosting mechanism implemented by
_Thread_Raise_real_priority(). The problem was that this approach
* is not transitive,
* does not account for priority adjustments of the calling task
while waiting for the join,
* does not support clustered scheduling, and
* does not detect deadlocks.
All these problems are fixed by using a priority inheritance thread queue for
the join operation.
Close #4679.
The objects local table must be statically zero-initialized so that
_Objects_Get() and _Objects_Get_no_protection() return NULL if no object is
associated with the identifier.
Update #4678.
The uniprocessor schedulers had some special case logic for the
PRIORITY_PSEUDO_ISR priority. Tasks with a priority of PRIORITY_PSEUDO_ISR
were allowed to preempt a not preemptible task. If other higher priority task
are made ready while a PRIORITY_PSEUDO_ISR task preempts a not preemptible
task, then the other tasks run before the not preemptible task. This made the
RTEMS_NO_PREEMPT mode ineffective.
Remove the PRIORITY_PSEUDO_ISR special case logic. This simplifies the
uniprocessor schedulers. Move the uniprocessor-specific scheduler support to
the new header file <rtems/score/scheduleruniimpl.h>.
Close #2365.
In case the Newlib _REENT_THREAD_LOCAL configuration option is enabled, the
struct _reent is not defined (there is only a forward declaration in
<sys/reent.h>). Instead, the usual members of struct _reent are available as
dedicatd thread-local storage objects.
Update #4560.
Commit 21275b58a5a69c3c838082ffc8a7a3641f32ea9a ("score: Static
Objects_Information initialization") introduced an off-by-one error in the
maintenance of inactive objects.
Close #4677.
Dirty or zero also the part of the .noinit section used by RTEMS.
Close #4678.
Place the statically allocated object control blocks, local tables, and thread
queue heads into the dedicated .noinit intput sections. The output section is
not zero initialized. Placing these elements into the .noinit section reduces
the system initialization time by decreasing the .bss section size.
It may improve the cache efficiency since the mostly read local tables are
placed in a contiguous memory area.
Update #4678.
This function is only used in SMP configurations.
Update #4670.
Update #4667.
Update #4667.
Conditional expressions with inline functions are not optimized away if
optimization is disabled. Avoid such expressions to prevent dead
branches. It helps also during code review to immediately see if a loop
is used or not.
The original file cpukit/libfs/src/ftpfs/tftpDriver.c
is split into two:
tftpfs.c - This file contains the code from tftpDriver.c
related to file system operations such as mount(),
open(), read(), and so on.
tftpDriver.c - In the original file remains only the code related
to networking. This code implements the Trivial
File Transfer Protocol (TFTP).
Moreover, the code is extended to support
* RFC 2347 TFTP Option Extension
* RFC 2348 TFTP Blocksize Option
* RFC 7440 TFTP Windowsize Option
Update #4666.
Update #2349.
Rename tc_getfrequency() to _Timecounter_Get_frequency().
Update #2349.
This file had no header, copyright, or license. Based on git history,
added appropriate copyright and license.
These files had no header, copyright, or licenses. Based on git history,
These files had no file header, copyright, or license. Based on git
history, added appropriate copyright and license.
Close #4644.
In contrast to rtems_shell_main_loop(), this new function does not
perform all sorts of initialization based on environment settings. For
example, due to the use of isatty() in rtems_shell_main_loop() it is
impossible to run an interactive shell through a socket connection.
This was requested to be executed prior to relicensing to BSD-2.
Permission received from Krzysztof Miesowicz.
Updates #3053.
Permission received from Petr Benes
Updates #3053.
Updates #3053.
Updates #3053.
Add SMP-specifc SMP_FATAL_MULTITASKING_START_ON_NOT_ONLINE_PROCESSOR
fatal error. This fatal error helps to diagnose a broken SMP startup
sequence. Without this error a context switch using the NULL pointer
for the thread control block happens which may be difficult to debug.
Add support to record scheduler operations. This support is especially
important for tests in SMP configurations since the thread switch extension is
quite difficult to use due to the asynchronous nature of thread dispatching.
In contrast, the scheduler operations occur normally in a deterministic order.
Update #3716.
This function may be used to burn a couple of processor cycles with
minimum impact on the system bus. It may be used in busy wait loops.
Since it is a global function, it is possible to wrap it in device
driver test code.
A default argument shall be defined only once.
Close #4632.
Restrict the affinity set to the set of online processors. Make sure
the affinity set for an interrupt vector contains at least one online
processor.
Update #3269.
Use the same form of IMD in all copyright lines
Update #4625.
Updates #4625.
Updates #4625.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Remove previous adjtime() implementation.
Update #2348.
Do not initialize Thread_Control::libc_reent if
CONFIGURE_DISABLE_NEWLIB_REENTRANCY is defined. This helps to catch errors
with a NULL pointer exception rather than a corruption of the thread control
block.
At the moment the line discipline start function (l_start) has no
possibility to get feedback about the number of characters that have
been sent. This patch passes that information via an additional
parameter.
The change might trigger a warning on existing code because of a pointer
mismatch but it shouldn't break it. An existing function with the old
API will just ignore the additional parameter.
Update #4493
GCC versions prior to 6.1 used a RTEMS thread model based on
rtems_gxx_*() functions. GCC version 6.1 or later uses the
self-contained synchronization objects of Newlib <sys/lock.h> for the
RTEMS thread model.
Remove the obsolete implementation.
Close #3143.
