path: root/cpukit/include/rtems/version.h (follow)
* Add rtems_version_control_key_is_valid()Sebastian Huber2019-09-111-2/+17
* rtems: Make rtems_version_control_key() saferSebastian Huber2019-09-091-3/+6
| | | | | Return the empty string instead of a NULL pointer if no version key is available.
* doxygen: Added Version to API->ClassicAndreas Dachsberger2019-04-041-2/+2
| | | | Update #3706.
* Add rtems_board_support_package()Sebastian Huber2019-03-141-0/+7
* Remove make preinstallChris Johns2018-01-251-0/+77
