path: root/cpukit/include/rtems/version.h (follow)
* cpukit: Add description of release version numbersChristian Mauderer2021-05-281-0/+21
| | | | | The release version in the git sources doesn't change. Add a note why that is the case.
* sapi: Canonicalize @defgroup and @file commentsSebastian Huber2020-12-021-2/+5
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group and file brief descriptions. Update #3706.
* Add rtems_version_control_key_is_valid()Sebastian Huber2019-09-111-2/+17
* rtems: Make rtems_version_control_key() saferSebastian Huber2019-09-091-3/+6
| | | | | Return the empty string instead of a NULL pointer if no version key is available.
* doxygen: Added Version to API->ClassicAndreas Dachsberger2019-04-041-2/+2
| | | | Update #3706.
* Add rtems_board_support_package()Sebastian Huber2019-03-141-0/+7
* Remove make preinstallChris Johns2018-01-251-0/+77
