2019-04-04 | doxygen: Split up "libmisc" subgroups and removed libmisc | Andreas Dachsberger | 1 | -1/+1 | |
Update #3706. | |||||
2018-01-25 | Remove make preinstall | Chris Johns | 1 | -0/+0 | |
A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254. | |||||
2017-12-14 | untar: Constify | Sebastian Huber | 1 | -1/+1 | |
2016-10-13 | libmisc/xz: Add xz decompression. | Chris Johns | 1 | -0/+63 | |
Add support to untar XZ compressed files. | |||||
2016-08-09 | libmisc/untar: Set the perms to the value in the tar file. | Chris Johns | 1 | -1/+6 | |
This patch parses the mode field in the tar header and sets the directory or file to the mode value in the header. Closes #2768. | |||||
2016-07-26 | Add Untar_FromGzChunk_Print() + Test | Alexander Krutwig | 1 | -0/+33 | |
2016-07-26 | Add Untar_FromChunk_Print() + Test | Alexander Krutwig | 1 | -0/+93 | |
2016-06-03 | libmisc/untar: Support directory create and overwrites. Share the common code. | Chris Johns | 1 | -1/+6 | |
Support creating directories for files with a path depth greater than 1. Some tar files can have files with a path depth greater than 1 and no directory entry in the tar file to create a directory. Support overwriting existing files and directories failing in a similar way to tar on common hosts. If a file is replaced with a file delete the file and create a new file. If a directory replaces a file remove the file and create the directory. If a file replaces a directory remove the directory, and if the directory is not empty and cannot be removed report an error. If a directory alreday exists do nothing leaving the contents untouched. The untar code now shares the common header parsing and initial processing with the actual writes still separate. No changes to the IMFS have been made. Updates #2415. Closes #2207. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2012-12-28 | Header File Doxygen Enhancement Task #1 | Alex Ivanov | 1 | -1/+3 | |
2012-12-19 | libmisc: Doxygen Enhancement Task #2 | Mathew Kallada | 1 | -1/+7 | |
http://www.google-melange.com/gci/task/view/google/gci2012/7959228 | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2011-06-24 | 2011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+6 | |
* include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h, include/rtems/pci.h, include/rtems/userenv.h, libblock/include/rtems/flashdisk.h, libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/spurious.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/framebuffer.h, libcsupport/include/rtems/gxx_wrappers.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/malloc.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h, libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h, libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h, libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h, libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h, libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h, libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h, posix/include/mqueue.h, posix/include/semaphore.h, posix/include/rtems/posix/aio_misc.h, posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/sigset.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, rtems/mainpage.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/barrier.inl, rtems/inline/rtems/rtems/timer.inl, rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h, sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h, score/include/rtems/score/object.h, score/include/rtems/score/priority.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl: Add @file Doxygen directives and descriptions to files which originated with RTEMS. This improves the file list page generated by Doxygen. | |||||
2010-06-13 | 2010-06-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* include/rtems/tar.h, libcsupport/include/tar.h: Remove. * configure.ac: Require toolchain to provide tar.h. * libfs/src/imfs/imfs_load_tar.c, libmisc/untar/untar.h: Use <tar.h> instead of <rtems/tar.h>. | |||||
2007-09-05 | 2007-09-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* libmisc/untar/untar.c, libmisc/untar/untar.h: Clean up prototype. | |||||
2007-09-04 | 2007-09-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -2/+2 | |
* libmisc/untar/untar.c, libmisc/untar/untar.h: Add const to char *. Use printk. | |||||
2005-02-07 | New header guards. | Ralf Corsepius | 1 | -3/+3 | |
2005-02-07 | 2005-02-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+16 | |
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_load_tar.c, libmisc/untar/untar.c, libmisc/untar/untar.h: Various generalizations and fixes. | |||||
2005-01-27 | 2005-01-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+3 | |
* libmisc/untar/untar.h: New prototype to eleminate warnings. * libmisc/untar/untar.c: Cosmetics, add symlinks. | |||||
2004-09-17 | 2004-09-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
PR 677/misc * libmisc/dumpbuf/dumpbuf.h, libmisc/fsmount/fsmount.h, libmisc/rtmonuse/rtmonuse.h, libmisc/serdbg/serdbg.h, libmisc/serdbg/serdbgcnf.h, libmisc/serdbg/termios_printk.h, libmisc/serdbg/termios_printk_cnf.h, libmisc/untar/untar.h: Add extern C wrappers. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* cpuuse/cpuuse.c, cpuuse/cpuuse.h, devnull/devnull.c, devnull/devnull.h, dummy/dummy.c, dumpbuf/dumpbuf.c, dumpbuf/dumpbuf.h, fsmount/fsmount.c, fsmount/fsmount.h, serdbg/serdbgio.c, serdbg/termios_printk.c, stackchk/check.c, stackchk/internal.h, stackchk/stackchk.h, untar/untar.c, untar/untar.h: URL for license changed. | |||||
1999-04-06 | Untar support submitted by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>. | Joel Sherrill | 1 | -0/+25 | |
