It seems that recent GCC versions expect that functions with a "const type *"
parameter will read from the referenced location.
Update #4662.
Updates #4662
Update #3716.
This makes it similar to T_push_fixture().
Flexible array members must not appear in the middle of a structure.
Bug was introduced by 78baeb757957fa0807c30e6c4d21ae99c9639e6a.
Update #3199.
Allow assert checks in test begin actions and setup fixture methods.
This name better reflects the execution envirnoment in which the cache
is fully loaded with valid data unrelated to the body request handler.
This primitive test case memory allocator uses memory from the low-level
memory information provided by the BSP. At the beginning of each test
case, the memory available to the test case is reinitialized. This
allows the use of a simple allocate only allocator.
Update #3199.
Normally, the expected test step must be a compile time constant. Allow
variable expected test steps for the T_step() and T_assert_step(). This
can be used for parameterized test loops with individual fixtures.
Remove the ability to use custom failure messages due to some
implementation constraints.
Update #3199.
Support a new test plan for each nested fixture.
Update #3199.
Update #3199.
Return the produced character count. There is no need for a NUL
termination.
Update #3199.
Add support to record thread switch events. This can be used to check
that a blocking operation results in the expected sequence of thread
switches.
Update #3199.
Update #3199.
Update #3199.
Update #3199.
This macro magic is in line with C11 and C++11, but limits the maximum
count of arguments.
Update #3199.
Rename internal function T_check_true() to T_check() and use the new
flag T_CHECK_FMT to indicate if a format string is present. This is a
preparation step to make the format string optional.
Make the check context the first parameter.
The API remains the same.
Update #3199.
Update #3199.
Update #3199.
Update #3199.
Update #3199.
Update #3199.
Update #3199.
Update #3199.
Update #3199.
Rename this header file to later move <t.h> to <rtems/test.h>. The main
feature provided by <rtems/test-info.h> is the output of standard test
information which is consumed by the RTEMS Tester.
Update #3199.
Update #3706.
RTEMS Application Loader, RTEMS Runtime Link Editor, Status Checks
and Test Support
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
