* | rtems: Improve RTEMS_NO_RETURN attribute | Sebastian Huber | 2020-10-10 | 1 | -1/+1 |
| | | | | | | | | | | | Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors like this: error: no return statement in function returning non-void [-Werror=return-type] Use C11 and C++11 standard means to declare a no-return function. Close #4122. | ||||
* | libtest: Add rtems_test_run() | Sebastian Huber | 2020-07-23 | 1 | -0/+14 |
| | | | | Update #3199. | ||||
* | libtest: Add T_get_one_clock_tick_busy() | Sebastian Huber | 2020-07-23 | 1 | -6/+0 |
* | libtest: Add T_busy() | Sebastian Huber | 2020-07-23 | 1 | -11/+1 |
* | libtest: <rtems/test.h> to <rtems/test-info.h> | Sebastian Huber | 2020-07-23 | 1 | -0/+329 |
Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199. |
